Python Userspace Interface Rapid Speed value?
4 years 9 months ago #231050 by fletch
First and foremost - I'm not sure this is the right category for this topic - please advise or move if required - it's kind of a user interface?
I'm making good progress on the Python Interface manualmatic pendant[1] - but there are a couple of machine values that I can't seem to access. The first relates to jog values - I can sorta understand that because jogging is always UI driven.
But the second is rapid speed. I can get feed speed from linuxcnc.stat().settings[1] (from the Python Interface docs [2]) but settings[2] gives me spindle speed - which I can already get from spindle[0]["speed"].
Is there a rapid speed value? Am I missing something obvious? If not, can I please request it is included in 2.9 (as settings[3] perhaps])? I'd like to be able to contribute to the interface if that would help, but I have not yet found in the github source... (all hints or links welcome!)
Many thanks in advance.
[1] forum.linuxcnc.org/18-computer/44682-a-t...ualmatic-mpg-pendant
[2] www.linuxcnc.org/docs/html/config/python-interface.html
4 years 9 months ago #231064 by AgentWD40
It's not totally clear to me exactly what you're doing but it looks like rapid is exposed to
halui.rapid-override.value
as an output pin
i'm playing with the halui.rapid-override pins in hal_show.
it looks like you can manipulate the .value like this
1. set the .scale to the |absolute| amount you want to change the rapid .value
2. set .increase or .decrease to change the rapid .value by the .scale amount
or
1. set .count-enable to true
2. change .counts to change .value by .counts * .scale ?? I'm thinking this intended for encoders?
...I'm new to all this myself.
4 years 9 months ago #231067 by fletch
Hi Kyle - thanks for your reply - I'm trying to take advantage of the userspace Python Interface to create an almost plug and play pendant for Arduino/Teensy - that only requires one file (maybe two) and a single line in the custom.hal but will work for all UIs without any changes or net pin configuration.
I'm more confident it will work now than when I posted the proof of concept earlier (link [1] in the first post) - I have the manual mode sorted and making good progress on the auto mode - even though I'd like the rapid speed to display on the pendant, I'd rather lose it than have end users have to create custom pins (although there is likely a way I could build it into the component).
In the Python Interface the command().rapidrate() sets the scale (1 = 100%) but I need the base speed to calculate the overriden speed, as per feed speed and spindle speed. I don't think I have the option to set count-enable.
I'm new to it too - this was (is) my 2021 Christmas project but I think using the Python Interface has great potential. Hoping there will be more exposed in v2.9.
4 years 9 months ago - 4 years 9 months ago #231073 by AgentWD40
Fwiw you could put your hal connections in a separate file and the user need only have to put
source my_hal_file.hal
In their hal file.
(Edit) Ah okay now I see, your not making a userspace module?
Last edit: 4 years 9 months ago by AgentWD40.
The following user(s) said Thank You: fletch
4 years 9 months ago #231093 by cmorley
Jog speed is produced by what ever ui you are using. Linuxcnc has no global setting of jog speed.
Rapid rate is not a setting the operator can set directly - only modify - the 0-100% is pretty standard indicator.
I suppose you could read the INI and figure out the exact speed if you really wanted to.
4 years 9 months ago - 4 years 9 months ago #231097 by fletch
Hi Chris - Thank you for confirming my understanding of jog setings - it's still a bit of a learning curve!
I guess the same applies to rapid rate as G00 doesn't specify a velocity.
The Python Interface appears to offer me a range of options to dig into:
  • max_velocity - from [TRAJ]MAX_VELOCITY
  • motion_type - possibly MOTION_TYPE_TRAVERSE - rapid move happening?
  • command - look for G00 to detect rapid move happening?
  • gcodes - although I'm not sure what "Active G-codes for each modal group." means!
    Thank you for pushing me in (hopefully) the right direction.
Last edit: 4 years 9 months ago by fletch.
Time to create page: 0.062 seconds
