ELO touchscreen driver and interface install.
4 years 9 months ago #232818 by Jake
I have been trying to install my new touchscreen.  My old ELO 17" has worked awesome for the last 8 years, it's getting darker and darker so I got a newer one.  I picked up a ELO ET2440 since I'm really wanting to go to SilverDragon.
I didn't have much of a challenge getting the old one which is USB connected going with 2.8 and Buster.  This new touchscreen I can not seem to get rolling.  It doesn't show up in lsusb even after having the other monitor running and a computer restart.  I'm not sure if I have a conflict between the two units.  I used the below instructions, I can not get the elotouch software running.  When I get down to "systemd status elo.touch" I get a failed return.
I did attempt to install with the 64bit Intel/AMD driver.
Does Debian Buster use systemd ?
It appears that libusb is already installed as the default package.  I added Motif 3.0.
Hopefully I'll have the new console completed over the next couple days and get back to trying to get the touchscreen going.
=============================================================================== Elo Touchscreen Linux Driver - Multi Touch (MT) USB Intel i686 (32 bit) or AMD64/Intel (64 bit) or ARMv7l (32 bit) or ARMv8 (64 bit) Installation/Calibration/Uninstallation Instructions -------------------------------------------------------------------------------- Version 4.1.0 May 04, 2021 Elo Touch Solutions ================================================================================ Elo Linux MT USB Driver package contains userspace Linux drivers designed for Linux kernel 5.x, 4.x, 3.x, video alignment utility and control panel utilities for Elo touchmonitors. This driver requires the presence of libusb-1.0 shared library and uinput kernel module on the target system for its operation. This driver supports one touch monitor and a non-touch monitor in mirror display mode, and multiple touch monitors configuration. This driver does not support "USB hot plug", please reboot the system if any USB monitors are unplugged and replugged or added to the system. This readme file is organized as follows: 1. Supported Touchmonitors and Elo Touchscreen Controllers 2. System Requirements 3. Installing the Elo Touchscreen USB Driver 4. USB Driver Commandline Options and Usage 5. Calibrating the Touchscreen 6. Accessing the Control Panel 7. Uninstalling the Elo Touchscreen USB Driver 8. Troubleshooting 9. Contacting Elo Touch Solutions ========================================================== 1. Supported Touchmonitors and Elo Touchscreen Controllers ========================================================== - Elo Multi-Touch(MT) USB Controllers TouchPro PCAP controllers, IntelliTouch Plus/iTouch Plus 2515-07(non HID), 2521, 2515-00, 3200XX, Multi Touch IR controllers - Elo Single-Touch(ST) USB Controllers IntelliTouch(R) 2701, 2700, 2600, 2500U, CarrollTouch(R) 4501, 4500U, 4000U, Accutouch(R) 2218, 2216, 3000U, Surface Capacitive 5020, 5010, 5000, Accoustic Pulse Recognition(APR) Smartset 7010 and other Elo Smartset ST USB controllers - Elo Multiple touch monitors ====================== 2. System Requirements ====================== Visit the Linux downloads section at www.elotouch.com to download the driver package for your 32 bit Intel, 64 bit AMD/Intel, 32 bit ARM v7l, 64 bit ARM v8 Linux. - 32 bit Intel i686 (x86) platform (or) 64 bit AMD/Intel x86_64 platform 32 bit ARM v7l platform 64 bit ARM v8 platform - Kernels supported: Kernel version 5.x.x Kernel version 4.x.x Kernel version 3.x.x - Xorg Xwindows version supported: Xorg version 6.8.2 - 7.2 Xorg Xserver version 1.3 and newer - Motif versions supported: Motif version 3.0 (libXm.so.3) - libusb versions supported: libusb version 1.0.9 or later - Uinput kernel module versions supported: uinput version 0.4 or later =============================================== 3. Installing the Elo Touchscreen USB Driver =============================================== Important: ========== a.) Must have root or administrator access rights on the Linux machine to install the Elo Touchscreen USB Driver. b.) Ensure all earlier Elo drivers are uninstalled from the system. Follow the uninstallation steps from the old driver's readme.txt file to remove the old driver completely. c.) The Elo Touchscreen driver components require libusb-1.0 library support (older libusb-0.1 library will not work). Most Linux distributions have started shipping this library (update to the popular libusb-0.1 library) as a part of their standard release. Customers can also download and compile the libusb-1.0 library from source (requires gcc v4.0.0 or later) available at libusb website. This driver will NOT work with the older libusb-0.1 library. d.) Do not extract the downloaded binary package on a Windows system. e.) Motif 3.0 (libXm.so.3) library is required to use the Graphic User Interface (GUI) based control panel (/etc/opt/elo-mt-usb/cpl). Openmotif or lesstif installation packages provide the required libXm.so.3 library. Step I: ------- Copy the elo driver files from the binary folder to the default elo folder. Change the permissions for all the elo driver files. These broad permissions are provided to suit most systems. Please change them to tailor it to your access control policy and for specific groups or users. a.) Copy the driver files to /etc/opt/elo-mt-usb folder location. # cp -r ./bin-mt-usb/ /etc/opt/elo-mt-usb b.) Use the chmod command to set full permissions for all the users for the /etc/opt/elo-mt-usb folder (read/write/execute). These broad permissions are provided to suit most systems. Please change them to tailor it to your access control policy and for specific groups or users. # cd /etc/opt/elo-mt-usb # chmod 777 * # chmod 444 *.txt c.) Copy the udev rules file to /etc/udev/rules.d/ folder location. Please edit touchscreen device permissions to tailor it to your access control policy and for specific groups or users. # cp /etc/opt/elo-mt-usb/99-elotouch.rules /etc/udev/rules.d Step II: [Linux distributions with systemd init system] -------- Install a script to invoke Elo service through systemd init at system startup. Check if systemd init is being used in your Linux distribution and then proceed with this installation step. If systemd init is not active, proceed with Step III of the installation. Check for active systemd init process. # ps -eaf | grep [s]ystemd # ps -eaf | grep init # ls -l /sbin/init If systemd init system is active, copy and enable the elo.service systemd script to load the elo driver at startup. Proceed to Step IV of the installation. # cp /etc/opt/elo-mt-usb/elo.service /etc/systemd/system/ # systemctl enable elo.service # systemctl status elo.service Step III: [Linux distributions with sysvinit or Upstart or older init system] --------- Install a script to invoke Elo service on older init systems (non systemd) at system startup. Redhat, Fedora, Mandrake, Slackware, Mint, Debian and Ubuntu systems: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Add the following line at the end of daemon configuration script in "/etc/rc.local" file. [ rc.local file might also be at location /etc/rc.d/rc.local. Use the "# find /etc -name rc.local" command to locate the rc.local file.] /etc/opt/elo-mt-usb/loadEloMultiTouchUSB.sh Update: - For Ubuntu v18.04.x LTS or later, if there is no rc.local file, we need to create it by following steps: 1. Create rc.local file under /etc folder, and enter following texts. #!/bin/sh -e /etc/opt/elo-mt-usb/loadEloMultiTouchUSB.sh exit 0 2. Save the file 3. Change the file to execable mode by following command: # chmod 755 rc.local - For RedHat and its family OS,due to OS security permission setting, you can disable the SELinux by editing the /etc/selinux/config: # This file controls the state of SELinux on the system. # SELINUX= can take one of these three values: # enforcing - SELinux security policy is enforced. # permissive - SELinux prints warnings instead of enforcing. # disabled - No SELinux policy is loaded. SELINUX=disabled # SELINUXTYPE= can take one of these three values: # targeted - Targeted processes are protected # minimum -Modification of targeted policy. Only selected processes are protected. # mls - Multi Level Security protection. SELINUXTYPE=targeted SUSE Systems: - - - - - - - Add the following line at the end of the configuration script in "/etc/init.d/boot.local" file. /etc/opt/elo-mt-usb/loadEloMultiTouchUSB.sh Step IV: -------- Plug in the USB touchscreen and reboot the system to complete the driver installation process. # shutdown -r now =========================================== 4. USB Driver Commandline Options and Usage =========================================== The USB (elomtusbd) driver commandline options are listed below. If required, modify the /etc/opt/elo-mt-usb/loadEloMultiTouchUSB.sh script file to add commandline options to the elomtusbd driver startup. --help Print usage information and available options --version Display USB touchscreen driver version information --absmouse Set the input device to absolute mouse. Absolute mouse input device sends mouse events corresponding to the primary touch only. In this mode the MTUSB driver sends BTN_LEFT, ABS_X and ABS_Y input events. This mode is useful to support legacy applications or older Linux kernels, which are not aware of ST or MT digitizer devices or digitizer events. Use evtest application to test the touchscreen in this mode. --stdigitizer Set the input device to Single Touch(ST) digitizer. The ST digitizer input device sends single touch digitizer events corresponding to the primary touch only. In this mode the MTUSB driver sends BTN_TOUCH, ABS_PRESSURE, ABS_X and ABS_Y input events. This mode is useful to support legacy applications or older Linux kernels, which are not aware of MT digitizer devices or multi touch digitizer events. It can be used to retrict the number of touches sent to Linux kernel to just one(primary touch) and avoid triggering multi touch system gestures. Use evtest application to test the touchscreen in this mode. --mtdigitizer Set the input device to Multi Touch(MT) digitizer. The MT digitizer input device is the default selection and it sends multi touch digitizer events corresponding to the Linux Multi Touch protocol. In this mode the MTUSB driver sends ABS_MT_PRESSURE, ABS_MT_POSITION_X and ABS_MT_POSITION_Y input events. This mode is useful to support the latest multi touch aware applications or multi touch system gestures on newer Linux kernels. Please note that the number of touches reported to the top level application depends on the Linux distribution and some multi touch events could be filtered to report system level gestures. Some Linux desktop elements including the mouse pointer may not respond in this pure multitouch mode, since they listen to mouse or ST digitizer events only. Use evtest or QT5 multitouch aware applications to test the touchscreen in this mode. Usage Examples: --------------- elomtusbd --help Print usage information and available options elomtusbd --version Display USB touchscreen driver version information elomtusbd --absmouse Set the input device to absolute mouse - BTN_LEFT, ABS_X and ABS_Y events elomtusbd --stdigitizer Set the input device to single touch digitizer - BTN_TOUCH, ABS_X, ABS_Y and ABS_PRESSURE events elomtusbd --mtdigitizer Set the input device to multi touch digitizer - ABS_MT_PRESSURE, ABS_MT_POSITION_X and ABS_MT_POSITION_Y events ============================== 5. Calibrating the Touchscreen ============================== Important: ========== Users must have read and write access to "/dev/elo-mt-usb" and "/etc/opt/elo-mt-usb" directories to perform the touchscreen calibration. All long commandline options in elova calibration utility use the "--" format. (example: "--help") Type "# /etc/opt/elo-mt-usb/elova --help" for available command line parameters and usage. Note 1: If the touch coordinators are corrected, please do not use “elova” to transform a touch coordinator again. Use cases: The “elova” utility is designed for touch calibration on legacy Elo monitors such as AT, IT monitor models. By default, the touch coordinators of the AT, IT monitors are not corrected, we need to use “elova” utility to correct them. In the case of rotated AT, IT touch monitors, we also need “elova” to re-calibrate for the touch coordinators. However, when we rotate the touchscreen with a transformation matrix applied, the touch coordinators are rotated with a touchscreen; then, we do not need to run “elova” tool. On the other hand, most of the cases of rotating PCAP touch monitors, the touch coordinators are automatically rotated with the touchscreen (handled by the OS). We don’t need to use “elova” to transform the touch coordinators again. Note 2: For multiple touch monitors, please do configure "map-to-output" first before using elova to transform the touch coordination. Step I: ------- Run the calibration utility from a command window in X Windows from the /etc/opt/elo-mt-usb directory for a single or multiple video setup (supports Xorg Xinerama, Xorg non-Xinerama and Nvidia Twinview options). # cd /etc/opt/elo-mt-usb # ./elova In a multiple video setup, the calibration target(s) will be shown on the first video screen and switch to the next video screen after a 30 second default timeout for each target or screen. Once the touchscreen is calibrated the data is stored in a configuration file on the hard disk. To display the calibration targets on just one specific video screen(example:videoscreen[1]) use the command shown below. # cd /etc/opt/elo-mt-usb # ./elova --videoscreen=1 To change or disable the default calibration timeout for each target or screen, use the command shown below. [Timeout Range: Min=0 (no timeout), Max=300 secs, Default=30 secs] # cd /etc/opt/elo-mt-usb # ./elova --caltargettimeout=0 [Disable the calibration timeout for all targets and videoscreens] # ./elova --caltargettimeout=45 [Modify the calibration timeout to 45 seconds] To view a list of video and USB touch devices available for calibration, use the command shown below. # cd /etc/opt/elo-mt-usb # ./elova --viewdevices To view all the available options and specific usage for elova calibration program, use the command shown below. # cd /etc/opt/elo-mt-usb # ./elova --help Step II: -------- Touch the target(s) from a position of normal use. The calibration data is written to the driver at the end of calibration. ============================== 6. Accessing the Control Panel ============================== The control panel application allows the user to easily set the available driver configuration options. After the driver package is installed, change to the /etc/opt/elo-mt-usb directory and run the control panel application(cpl or cplcmd). Important: ========== Users must have read and write access to "/dev/elo-mt-usb" folder to run the control panel applications. Step I: ------- Run the control panel utility with root privileges from a command window in X Windows from the /etc/opt/elo-mt-usb directory. Motif version 3.0 (libXm.so.3) is required to use the GUI based control panel (/etc/opt/elo-mt-usb/cpl). If Motif or GUI control panel(cpl) is not present, use the command line version of the application(cplcmd) in Step III. # cd /etc/opt/elo-mt-usb # sudo ./cpl Step II: -------- Navigate through the various tabs by clicking on them. Here is an overview of information related to each tab. General - Perform touchscreen calibration Sound - Change Beep on Touch Parameters (Enable/Disable Beep, Beep Tone, Beep Duration) Touchscreen-0 - Display data related to the USB touchscreen 0. About - Information about the package. Click on the Readme button to open this Readme file. Step III: --------- If Motif is not installed or GUI control panel(cpl) is not present, use the command line version of the application(cplcmd) to access the control panel. Run the command line application from a command window in X Windows from the /etc/opt/elo-mt-usb directory. # cd /etc/opt/elo-mt-usb # sudo ./cplcmd ================================================= 7. Uninstalling the Elo Touchscreen USB Driver ================================================= Important: ========== Must have root or administrator access rights on the Linux machine to uninstall the Elo Touchscreen USB Driver. Step I: ------- Delete the script or commands that invoke Elo service at startup. Linux with Systemd init system: ------------------------------- Disable and remove the elo.service startup script registered with systemd init system in Step II of Installation section. # systemctl status elo.service # systemctl stop elo.service # systemctl disable elo.service # systemctl status elo.service # rm -rf /etc/systemd/system/elo.service Linux with sysvinit or Upstart or older init system: ---------------------------------------------------- SUSE systems: - - - - - - - Remove the following entry created in Step III of Installation section from the configuration script in"/etc/init.d/boot.local" file. /etc/opt/elo-mt-usb/loadEloMultiTouchUSB.sh Redhat, Fedora, Mandrake, Slackware, Mint, Debian and Ubuntu systems: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Remove the following entry created in Step III of Installation section from the configuration script in "/etc/rc.local" file. (or "/etc/rc.d/rc.local" file) /etc/opt/elo-mt-usb/loadEloMultiTouchUSB.sh Step II: -------- Delete all the elo driver files from the system. a.) Delete the main elo driver folder. # rm -rf /etc/opt/elo-mt-usb b.) Delete the elo related device folder and files. # rm -rf /dev/elo-mt-usb # rm -rf /etc/udev/rules.d/99-elotouch.rules Step III: --------- Reboot the system to complete the driver uninstallation process. # shutdown -r now ================== 8. Troubleshooting ================== A. Make sure libusb-1.0 library is installed on the target Linux system. The driver will NOT work with the older libusb-0.1 library. Most Linux distributions ship with the newer libusb-1.0 library installed by default. It can also be installed by downloading and compiling the library source (requires gcc v4.0.0 or later) from the libusb-1.0 website. B. If touch is not working, check if the elomtusbd driver is loaded and currently available in memory. Some Xorg Xserver versions terminate the touchscreen driver upon user logout. The current workaround in this situation is to startup the driver from Xwindows startup script or reboot the system. # ps -e |grep elo Check the driver log file for any errors that have been reported. # gedit /var/log/elo-mt-usb/EloUsbErrorLog.txt If the driver is not present then load the driver again. Root access is needed to load the driver manually. Normal users will have to restart the system so that the elomtusbd daemon is loaded again during system startup. Normal users may be able to load the driver manually depending on access control and file permissions that are setup. # /etc/opt/elo-mt-usb/elomtusbd C. If starting the Elo touchscreen driver from the normal startup locations like rc.local or boot.local does not work, first test if the touchscreen is working by manually launching the driver from a terminal window within XWindows graphics desktop session. # sudo /etc/opt/elo-mt-usb/loadEloMultiTouchUSB.sh If the touchscreen works when the driver is launched manually, try to add the touchscreen driver startup line to the end of one of the XWindows startup scripts. The Xwindows startup scripts are located usually in the following path /etc/X11/xinit/xinitrc.d/. Running the touchscreen driver from the Xwindows startup script will provide touch input ONLY after the user has logged in successfully at the GUI Login screen. D. Beep-on-touch feature does not work in the GUI control panel sound tab (Beep Test button) or if the driver is loaded manually from a non-root user context. The driver has to be loaded from a system startup script or root user account for beep-on-touch to function properly. The beep on touch feature also depends on the pcspkr(PC Speaker) kernel module. Ensure that the pcspkr kernel module is loaded and active in memory using the lsmod command. Some distributions blacklist the pcspkr kernel module, which will not allow this kernel module to function. Remove it from the blacklist file and then try loading the module again. E. While trying to load the driver manually, if you get an error "Error opening USB_ERROR_LOG_FILE", check the file permissions for the /var/log/elo-mt-usb/EloUsbErrorLog.txt file. The user needs to be the root user or have read and write access to this log file to launch the driver. Try using the sudo command to launch the driver manually, if its a non root user. F. In a multi video setup, the touchscreen can be mapped to just one videoscreen. First find the name of the video port (example: VGA-1, HDMI-0, DVI-0) that connects to the desired videoscreen, using the xrandr command in a terminal window. # xrandr Next, find the device ID (id=xx) of the Xinput pointer device "Elo MultiTouch(MT) Device Input Module" using the xinput command in a terminal window. # xinput Finally, map the touchscreen device ID to the desired video port using the xinput command's --map-to-output option. # xinput --map-to-output 22 VGA-1 [Map input device ID 22 to VGA-1 port] The input device ID and video port name are stable across system reboots. The above mapping command can be added to a startup script to perform the mapping at every boot after the Elo MTUSB driver have been loaded. G. In some Linux distributions (example: Ubuntu 12.04) the desktop does not respond to clicks after some time, while the pointer still follows the touch input. This is a know bug in Xwindows which has been fixed on newer versions. To solve this issue, either upgrade to newer version of Xwindows or download the bug fix, patch and recompile current version of Xserver. H. Newer Linux distributions are starting to switch to the new systemd init system startup mechanism. If the addition of the Elo startup script loadEloMultiTouchUSB.sh to rc.local or boot.local scripts does not load the elo driver on reboot, check if systemd init system is active. If systemd init is active then register and enable the elo.service systemd startup script as per instructions in Step II of the Installation section. I. Display rotation: Can be rotated by using option OS's Setting. Or by commnad line like: a. xrandr -o left (right) b. Or adding "display_rotate=x" to /boot/config.txt, where x=1,2,3,4. ================================= 9. Contacting Elo Touch Solutions ================================= Website: http://www.elotouch.com E-mail: customerservice@elotouch.com Mailing Address: ---------------- Elo Touch Solutions, Inc. 670 N. McCarthy Blvd Milpitas, CA 95035 USA Phone: (800) 557-1458 (408) 597-8000 ================================================================================ Copyright (c) 2019 Elo Touch Solutions All rights reserved. ================================================================================
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 9 months ago #232819 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic ELO touchscreen driver and interface install.
Yep systemd is used on a standard debian install.
4 years 9 months ago #232849 by Jake
I'll keep working on it. I was not really sure what to look for with systemd and the command to check systemd function. New monitor will be much nicer than the old one!
4 years 9 months ago #233377 by Lcvette
did you get that on ebay? I have a customer who grabbed one for what seemed to be a great price, but he found that it was not a touch screen but a non touch model even though the listing stated touch.  below was the model he purchased and he couldn't get touch working so he discovered the below information on the elo website:
hope that isn't the same case for you!
4 years 9 months ago #233388 by Jake
Well that sucks.
I have the same one. One way or another current monitor on the machine was on the way to the grave. Yeah I could have caught that on the part number. Touchscreen in the description is deceiving. Well I feel better that I couldn't get it to work! I guess I'll use that one for something else and hunt down another one. It does look great in the console!
4 years 9 months ago #233453 by Lcvette
sorry to hear that, but at least you aren't beating your head against the wall trying to sort it out.  I would contact the seller and return, that is what m buddy did with seller paying shipping.  it was 100% falsely advertised!
Time to create page: 0.515 seconds
