RTAI 5.3.3 Delta release for LinuxCNC (kernel 5.4 debs available)
3 years 11 months ago #257123 by Bari
RTAI kernel 5.4 Debian packages are up!
github.com/NTULINUX/RTAI/releases/tag/v5.3.3-delta
If these check out OK, they will be marked as stable.
The following user(s) said Thank You: seuchato, arvidb, tommylight
3 years 11 months ago #257366 by tommylight
Sorry for not having time to test.
3 years 11 months ago #258022 by DomCa
Dear Bari,
I currently have a LinuxCNC2.8 RTAI setup from 2 years ago and would like to test 2.9 with RTAI. I want to use RTAI because it gives me the best latency on my PC and I use the Parport for stepper signal generation.
Is there a tutorial/documentation on how to install a LinuxCNC 2.9 from scratch and then add your RTAI kernel?
Thanks!
Dom
3 years 11 months ago - 3 years 11 months ago #258025 by NTULINUX
Dear Bari,
Thanks!
Dom
Hi Dom,
So there are no LinuxCNC packages built right now against my latest RTAI 5.3.3 Delta release yet, to my knowledge. Building LinuxCNC though once you have RTAI installed is very easy.
For simplicity sake, let's stick with just the 5.4 kernel packages.
Download the RTAI 5.4 kernel debian packages:
You need linux-image, linux-headers and rtai-modules:
github.com/NTULINUX/RTAI/releases/downlo...ai-amd64-1_amd64.deb
github.com/NTULINUX/RTAI/releases/downlo...xcnc-delta_amd64.deb
Once you have those downloaded, in command line:
sudo dpkg -i linux-image-5.4.224-rtai-amd64_5.4.224-rtai-amd64-1_amd64.deb sudo dpkg -i linux-headers-5.4.224-rtai-amd64_5.4.224-rtai-amd64-1_amd64.deb sudo dpkg -i rtai-modules-5.4.224_5.3.3-linuxcnc-delta_amd64.deb
Specify the full path to the Debian packages after the `-i` if you are not currently in the directory of the .deb files.
After that, build LinuxCNC master branch from source:
git clone https://github.com/LinuxCNC/linuxcnc cd linuxcnc/src ./autogen.sh ./configure --enable-non-distributable=yes make sudo make setuid cd .. . ./scripts/rip-environment
You should now be able to launch LinuxCNC, latency-test and latency-histogram via the following commands:
linuxcnc latency-test latency-histogram
The build dependencies for LinuxCNC must be installed before running the above `./configure` command.
Refer to this page for more info:
linuxcnc.org/docs/master/html/code/build...g-Build-Dependencies
To match that documentation page, you can use this `git clone` command instead of the one I listed above:
git clone https://github.com/LinuxCNC/linuxcnc linuxcnc-dev
Last edit: 3 years 11 months ago by NTULINUX. Reason: fixes (added rtai-modules)
The following user(s) said Thank You: RobC
3 years 11 months ago - 3 years 11 months ago #258026 by NTULINUX
I'm never posting commands on this forum again, you guys have the absolute worst post editor imaginable.
Forgot to mention,
After you install the kernels, reboot into your new RTAI (5.4) kernel before building LinuxCNC. Select the RTAI kernel via the GRUB menu on boot.
Editing this post instead lol.
Last edit: 3 years 11 months ago by NTULINUX. Reason: More info
3 years 11 months ago #258193 by DomCa
Hi NTULINUX,
Thanks a lot for your guide! I will give it a try this weekend.
Regards,
Dom
Time to create page: 0.488 seconds
