PCIE parallel port
2 years 8 months ago #292312 by robertjenkins
My old PC with a parallel port died, as they always do. So I got a new second hand machine without a parallel port, and thought it would be easy to add a PCIE card. Naively I assumed that linux would recognise it automatically, but of course it doesn't. So digging a little in the forum I found various bits of advice, which start with running the lspci command. I did that, and the result is attached. As far as I can see there is no reference there to a parallel port. Any suggestions? (warning - I know almost nothing about linux: I only use it because I'm used to linuxcnc)
File Name: lspci.txt
File Size:11.61 KB
2 years 8 months ago #292313 by tommylight
Replied by tommylight on topic PCIE parallel port
If possible, try a different port, you can safely insert it into the graphic card slot if its not busy.
2 years 8 months ago #292315 by robertjenkins
Replied by robertjenkins on topic PCIE parallel port
Thanks. I've tried it in all four slots (including the graphics card slot) with no difference.
However, I see that on the board there is a sticker pointing me to a website for a driver download. There, there is a linux kernel driver, which I have downloaded. The file is called AX99100_SP_PP_SPI_Linux_Driver_v1.9.0_Source.tar
Might this be what I need? If so, what should I do with it please?
2 years 8 months ago #292319 by JT
Replied by JT on topic PCIE parallel port
Run lspci twice, once with the card plugged in and once without to see if you see an additional card when it's pugged in.
JT
2 years 8 months ago #292320 by PCW
Replied by PCW on topic PCIE parallel port
Yes, LinuxCNC does not need a Linux driver for the card,
if the card has standard parallel port hardware.
LinuxCNC just needs the cards address (which lspci should show)
2 years 8 months ago #292369 by robertjenkins
Thanks - have tried that, there is no difference in the lspci output with or without the card
Time to create page: 0.066 seconds
