timing pully code problem help
14 years 9 months ago #16646 by guyver001
Hi guys i have a program that generates timing pully code for 4th axis i last used it with mach3 worked fine
that was along time ago just got my 4th axis up and running again
generated the code for a new pulley just for a trial
but i get an error in emc unknown code ???
anyone take a look
( 5mm T Pulley with 16 Grooves )
( Pitch Dia. 25.46 )
( Outside Dia. 24.63 )
( Depth of cut 1.2 )
G17 G90 G54 G49 G40 G80 G50
G21
M6 T1 (Tool Change)
M3 S4500 (Start Spindle)
M8 (Turn Coolant On)
G0 G64 A0.0 Z5
G43 H1
G0 G54 X0 Y0.0
Z0.00
M98 P0001 Q16
A0.00
G0 Z5
M5(Stop Spindle)
M9(All Coolant Off)
M30(Rewind)
O0001
G1 Z-0.1 F100
X-10 F100
G0 Z 5
X0
G1 Z-0.2 F100
X-10 F100
G0 Z 5
X0
G1 Z-0.3 F100
X-10 F100
G0 Z 5
X0
G1 Z-0.4 F100
X-10 F100
G0 Z 5
X0
G1 Z-0.5 F100
X-10 F100
G0 Z 5
X0
G1 Z-0.6 F100
X-10 F100
G0 Z 5
X0
G1 Z-0.7 F100
X-10 F100
G0 Z 5
X0
G1 Z-0.8 F100
X-10 F100
G0 Z 5
X0
G1 Z-0.9 F100
X-10 F100
G0 Z 5
X0
G1 Z-1 F100
X-10 F100
G0 Z 5
X0
G1 Z-1.1 F100
X-10 F100
G0 Z 5
X0
G1 Z-1.2 F100
X-10 F100
G0 Z 5
X0
G91 A22.5
G90
M99
cheers guys
14 years 9 months ago #16650 by Rick G
M98 P0001 Q16
I believe EMC and mach may use m98 differently.
www.linuxcnc.org/index.php/english/compo...ew&catid=20&id=13054
Rick G
14 years 9 months ago #16653 by BigJohnT
You will need to change your post processor to output g code for EMC and not Mack.
The first error is EMC does not have a G50... the error does point you to the line where the error is. Also the line that starts with O0001 might be your next error or the M98 might be the next... to make a long reply short no code will port directly between different controls if they go beyond G0 or G1 and some controls even treat them differently.
14 years 9 months ago #16657 by guyver001
no option to change the post processor in this utillity
www.cad2gcode.com/pulley/
i got this ages ago when i was using mach
dont know emc that well
i will have to look in to how emc does a subroutine if at all
14 years 9 months ago #16659 by BigJohnT
Does it have a Fanuc post processor? IIRC that is close enough to EMC to work with basic code.
Subroutines are defined ahead of the call and may use names or numbers like so:
G20 G4 etc (preamble) o<mysub> sub ... lines of code o<mysub> endsub o100 sub ... some code o100 endsub o<mysub> call o100 call M2 (end of program)
This is the 2.5 Subroutines docs for the upcoming version due to be released real soon.
14 years 9 months ago #16661 by BigJohnT
I think with some cut and paste of the code you can make it work with EMC... It's a shame that some people only target a small portion of the CNC market by limiting themselves to one control system.
Time to create page: 0.261 seconds
