New syntax highlighting for gedit
10 years 6 months ago #73674 by FernV
For those of you that prefer using gedit, I wrote a new HL file for you.
Just copy ngc.lang.txt file to either (REMOVE THE .txt EXTENSION)
/usr/share/gtksourceview-3.0/language-specs/
or
~/.local/share/gtksourceview-3.0/language-specs/ (you can also use 2.0 instead)
File Name: ngc.lang.txt
File Size:8.43 KB
and GCode.xml (colors) in
/usr/share/gtksourceview-3.0/styles/
or
~/.local/share/gtksourceview-3.0/styles/
then restart gedit, open a ngc file and select GCode color scheme
File Name: GCode.xml
File Size:3.45 KB
here what it looks like
If you do not like the colors I selected, try to find a scheme you like or edit GCode.xml by inspecting ngc.lang to see how colors are mapped
Best regards
Fernand
The following user(s) said Thank You: BigJohnT, andypugh, chucktilbury, Amedee, webmanoffesto, Studi
10 years 6 months ago #73731 by BigJohnT
I'm using Gedit on LinuxMint 17.3 but don't see the directories you mention.
JT
10 years 6 months ago #73738 by Amedee
I don't have Mint, but i believe it is shipped with GTK2 so you need to look for /usr/share/gtksourceview-2.0/ directory
10 years 6 months ago - 10 years 6 months ago #73744 by BigJohnT
LinuxMint 17.3 has both /usr/share/gtksourceview-2.0 and /usr/share/gtksourceview-3.0. Let me try that and see what I get.
Edit: after some experiments I determined that /usr/share/gtksourceview-3.0 is the correct place however my G code does not look like Ferns example.
JT
Last edit: 10 years 6 months ago by BigJohnT.
10 years 6 months ago - 10 years 6 months ago #73749 by Amedee
You need to set the color scheme as well (in the preference menu)
Last edit: 10 years 6 months ago by Amedee.
10 years 6 months ago #73757 by BigJohnT
Now that looks much better and I even like it!
JT
Time to create page: 0.243 seconds
