coordinate system and rotating
17 years 6 months ago - 17 years 6 months ago #40 by luminize
Hi Guys,
Maybe off topic, but i shouldn't know where else to post...
I was wondering, if it is in theory possible (G68 not supported yet, i thought) to define a rotated coordinate system with G-code? With this i could i could for example let my machine place a long shaft in a long hole. All i have to do then is add G-code to define de position and angle where i want to do so and the axial movement would be a simple G-code for a vertical movement. (see attached picture)
How should i do a workaround? Define a new/rotated kinematics module? Can i switch in HAL in runtime to another kinematics module?
Thanks, Bas
image missing http://www.linuxcnc.org/media/kunena/attachments/legacy/images/greenshot_2009_04_03_12_45_32.png
Last edit: 17 years 6 months ago by luminize.
17 years 6 months ago #42 by BigJohnT
It looks on topic to me. I'm not sure what your asking maybe someone can chime in that knows. Nice SW picture. I'm a power SW user too.
17 years 6 months ago #43 by luminize
I'm currently working on a system for a client if mine where i have to load a drill (round 3 mm) in a clamp (under an angle of 15 degrees with the horizontal plane), and with an x-y system move the drill onder a grinding stone. In the future we would take out the manual inserting of the drill in the clamp.
We were thinking about a fanuc robot, but with some goot tweaking it i think it would be possible to make our own robot with EMC2. The robot should pick a drill, and load this in the machine.
The big advantage is that my client has experience with G-coding. So when he wants to tweak around, he could do it himself. (change the position where he wants to pick the drill etc.)
Bas
17 years 6 months ago #44 by BigJohnT
Ok, I understand what your trying to do.
Take a look at the puma and scara sample configs.
17 years 6 months ago #45 by alex_joni
One way to do this is by defining a kinematics module which does the rotation.
There is a component which does it in XY only, but you could extend it to XYZ.
If you code it right, you can have the UVW coordinate system attached to the things that rotate, so you can program your moves in UVW.
There should be a sample config that does a similar thing (5axis or so).
Regards,
Alex
17 years 6 months ago #46 by luminize
Sweet,
so my kinematics module holds the calculations for the x-y-z axes, and also the (other calculations) u-v-w axes. That means the rotations of the axes are hard coded?
Going to look at the 5axis sample.
I'm going to come back to this.
Thanks,
Bas
Time to create page: 0.654 seconds
