G96 CSS turn off?
6 years 1 month ago #183264 by sharpshooterser
I did a bit of a research but havent found a solution for it. On my lathe I use a puller to get the stock out, which requires that spindle is not in motion. Now since I programmed the G96, once the puller gets into the pre position in G0 motion, and code gets to G1 line, it stops.
I cant use G1, its too fast.
How to disable G96?(G97 doesnt work)
6 years 1 month ago #183269 by AlekseySP
Replied by AlekseySP on topic G96 CSS turn off?
Use G94 before G1
The following user(s) said Thank You: sharpshooterser
6 years 1 month ago #183271 by sharpshooterser
Replied by sharpshooterser on topic G96 CSS turn off?
I did, but still no luck. Only thing I havent tried is to run the puller on the beginning of the program.
6 years 1 month ago #183281 by AlekseySP
Your problem has nothing to do with css. You using G95 for feedrate, which is units/revolution.
No revolution - no feed. U have to switch to G94, units/minute. And use appropriate feedrate, like F200 (mm/min) or F10 (in/min). Don't forget to switch back to G95 after or it will be a problem
6 years 1 month ago #183293 by sharpshooterser
I did use g94, but no luck.
What is interesting - if I add g97 m4 s0 to the program, save it, run it (it still doesnt pull) then delete the g97 m4 s0 and save it again, then it pulls
6 years 1 month ago #183300 by sharpshooterser
I ll upload the code a bit later
Time to create page: 0.063 seconds
