Thank you for your answer, I solved the problem that it will be executed when the file is loaded. But I encountered a new problem: I used python to remap a G code: G02.1, its function is to assign the value of the parameter to another executable program. But after I load the G code file, it will be executed immediately when I click Start, and it is not executed in the order of the G code file. What should I do to make the remapped code execute in the order in the file? Thanks in advance, here is my code:The code is run-through in simulation mode when the file is loaded to generate the graphical preview.
You can choose to exclude some code from execution if this causes a problem:
See #<_task>
linuxcnc.org/docs/2.8/html/gcode/overvie...ub:system-parameters
