axis direction
7 years 1 month ago #145881
by j.clark91
axis direction was created by j.clark91
hello everyone,
i've managed to set up all the axis and homing directions okay and tested the repeatability with a clock while jogging,
everything perfect!
my problem is when i was trying a program out to test the auto tool measure program i've been messing with is that the direction of the y and x axis are inverted,
the jog buttons move the machine to the right direction so x axis + to the right and - to the left, y axis - to the front and + to the back.
the offsets for the g54 location are both plus so it should move into the right direction but when i go into MDI and type G0 G90 G54 X10. Y10. the relative postions are right but its moved -10. in both axis,
anyone had this before?
thank you
Jamie
everything perfect!
thank you
Jamie
7 years 1 month ago #145887
by j.clark91
Replied by j.clark91 on topic axis direction
Solved my fault while writing I’ve realised my axis were wrong and needed inverting
I’ve changed my .hal file to invert the direction and then .ini file to still reference in the right direction
7 years 1 month ago #145927
by pl7i92
Replied by pl7i92 on topic axis direction
Hi
it is best to get a ic of paper with the Coordinate system on it on the table // Tool
and also to replace wirering to get the Real non inverting Axis motor movements
so the interpreter does not always need to change the things
this leads somtimes in errors or faults Following error
loss of speed and precision and oin microstepping also torque
all to be considerd as a mashine builder
7 years 1 month ago #145933
by MaHa
Replied by MaHa on topic axis direction
The easyiest way to invert axis direction is in the .ini file, eg.
STEP_SCALE=320
or
STEP_SCALE=-320
No rewiring needed.
STEP_SCALE=320
or
STEP_SCALE=-320
No rewiring needed.
- Dinuka_Shehan
- Thank you received: 26
7 years 1 month ago - 7 years 1 month ago #145938
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic axis direction
Motor wiring error.
Change A+ and A- to B+ and B- to And vice versa for stepper motor.
Will it work toma uncle..
Last edit: 7 years 1 month ago by Dinuka_Shehan.
7 years 1 month ago #145940
Replied by tommylight on topic axis direction
Nope.
To change the stepper motor direction by changing the wiring ( not recommended since it can be done in several ways in Linuxcnc ), you have to change ONLY 2 wires of one of the coils.
By changing both coils ( 4 wires ) you end up with the same direction of spinning !
The following user(s) said Thank You: Dinuka_Shehan
Time to create page: 0.736 seconds
