Move pyvcp location to bottom for portrait display
6 years 8 months ago #158279 by sdwyer
I'm looking to change my monitor orientation from Landscape to portrait so I can mount it on the side of my enclosure.
I'm using the Axis UI and have developed a ppvcp panel that sits in the default right side of the Axis display.
Is it possible to move the pyvcp location to the bottom either below or above the gcode window?
This would make a vertical display a more feasible option for me.
Cheers!
-Shaun
6 years 8 months ago #158300 by cmorley
There is not an easy way to do this - it requires code changes - which may be possible using the .axisrc capability.
Just wait and maybe the AXIS guru will help you out...
Chris
6 years 8 months ago #158356 by phillc54
Unfortunately because the relevant code is not in a function it cannot be changed from .axisrc
It is a simple code change in axis.py from:
3797 f = Tkinter.Frame(root_window) 3798 f.grid(row=0, column=4, rowspan=6, sticky="nw", padx=4, pady=4) 3799 vcpparse.filename = vcp
to:
3797 f = Tkinter.Frame(root_window) 3798 f.grid(row=4, column=0, columnspan=6, sticky="nw", padx=4, pady=4) 3799 vcpparse.filename = vcp
A neater way would be to change it to:
3797 f = Tkinter.Frame(root_window) 3798 if inifile.find("DISPLAY", "PYVCP_POSITION") == "BOTTOM": 3799 f.grid(row=4, column=0, columnspan=6, sticky="nw", padx=4, pady=4) 3800 else: 3801 f.grid(row=0, column=4, rowspan=6, sticky="nw", padx=4, pady=4) 3802 vcpparse.filename = vcp
and have an optional PYVCP_POSITION in the [DISPLAY] section of the ini file requiring BOTTOM to effect the change.
Attached image is with the pyvcp-demo sample and would need to be reconfigured to suit the placement
Note that the line numbers above are correct for master branch.
The following user(s) said Thank You: nkp, tommylight, meister, sdwyer
6 years 8 months ago #158363 by sdwyer
Hi Phill,
Thankyou! This looks really good! Do you think this is something that might be worth committing to the tree? I'm sure I'm not the only one who would benefit from this code.
Cheers!
-Shaun
6 years 8 months ago - 6 years 8 months ago #158364 by phillc54
It probably is worth committing at least into master, it shouldn't break any existing configs.
Edit: github.com/LinuxCNC/linuxcnc/pull/685
Last edit: 6 years 8 months ago by phillc54.
The following user(s) said Thank You: sdwyer
Time to create page: 0.206 seconds
