Program stops at G53
6 years 3 months ago #175407 by bmklawt
Program stops at G53 was created by bmklawt
Hello,
I recently had to change the hard drive in my LinuxCNC set up and reload all the Pico System PPMC files, don't know if this matters but thought I'd mention it.
Before the hard drive failure I was using Mastercam to write and post my Gcode and it worked fine, since I lost the hard drive I also lost my access to Mastercam I am trying my hand at Fusion 360. When I run this program it stops at line N20 G53 G0 Z0.and I can figure out why, Is it a problem with Fusion, my tool offset, machine off sets, axis settings, operator error, I don't know, attached is a screen shoot of AXIS GUI and a copy of the program, hoping someone out there smarter than me can point me in the right direction.
Your help is greatly appreciated,
Bruce
File Name: LUCcomponent1.ngc
File Size:36.26 KB
6 years 3 months ago #175409 by cmorley
Replied by cmorley on topic Program stops at G53
was there an error message? does it hang or just ends the program?
6 years 3 months ago #175412 by bmklawt
Replied by bmklawt on topic Program stops at G53
No error message, the program just hangs at line N20
6 years 3 months ago #175413 by bmklawt
I should say the program completes line N20 G53 G0 Z0. then hangs
6 years 3 months ago #175416 by cmorley
So right after that is a tool change code - does tool changes work properly?
If you don't have a tool changer, then usually people set up a prompt to change the tool.
Chris
6 years 3 months ago #175417 by cmorley
hal_manualtoolchange is the component and it needs it's HAL pins connected to work.
Time to create page: 0.300 seconds
