Mpg stop working
1 year 1 month ago #334315 by Artur_1617
Mpg stop working was created by Artur_1617
I have problem with Mpg.
Mpg working when I start linuxcnc, But in some moment after start stop working.
I think this start when my setup start to use A axis...
Any suggestion what could happened?
1 year 1 month ago #334338 by andypugh
Replied by andypugh on topic Mpg stop working
Is this a USB MPG?
If you look in dmesg do you see it being disconnected?
I think I used to have this problem about 10 years ago, but I don't recall if I ever found a solution. (I stopped using the USB gamepad)
The following user(s) said Thank You: Artur_1617
1 year 1 month ago #334349 by Artur_1617
Replied by Artur_1617 on topic Mpg stop working
Not, I use MPG conected directly to one encoder input in 7i77.
1 year 1 month ago #334350 by PCW
Replied by PCW on topic Mpg stop working
Is this homing related?
Because before homing you need to jog joints and after homing you need to jog axis
1 year 1 month ago #334353 by Artur_1617
Yes Mpg working before homing.
I think must to change this
net x-jog-select joint.0.jog-enable <= hm2_5i25.0.7i77.0.0.input-10
net y-jog-select joint.1.jog-enable <= hm2_5i25.0.7i77.0.0.input-11
net z-jog-select joint.2.jog-enable <= hm2_5i25.0.7i77.0.0.input-12
net a-jog-select joint.3.jog-enable <= hm2_5i25.0.7i77.0.0.input-13
1 year 1 month ago #334356 by andypugh
Yes.
Just add the axes too
net x-jog-select joint.0.jog-enable axis.x.jog-enable <= hm2_5i25.0.7i77.0.0.input-10 net y-jog-select joint.1.jog-enable axis.y.jog-enable <= hm2_5i25.0.7i77.0.0.input-11 ... etc ...
Time to create page: 0.056 seconds
