How to use the spindle-cmd-rpm signal?
8 years 11 months ago #101832 by nicokid
I'm playing with spindle speed and I would like to create a manual speed control in pyvcp and gladevcp.
Unfortunately if bypassing the spindle-cmd-rpm signal then the manual command from gladevcp works but mdi command stops working (eg M3 S20000).
That's what I did:
In my-mill.hal
net my-spindlespeed-mux => mux2.0.sel
net spindle-cmd-rpm => mux2.0.in1
net spindlespeed <= mux2.0.out => pwmgen.0.value
What I removed:
net spindle-cmd-rpm => pwmgen.0.value
In postgui.hal
net gvcp-spindlespeed <= gladevcp.scale_spindle_speed => mux2.0.in0
mux2.0.sel is always false and therefore spindle-cmd-rpm that is linked to in1 never works. I do not know how to set mux2.0.sel when I'm in mdi mode.
Any help?
Thanks, Nicola.
8 years 11 months ago #101876 by cmorley
you could use HALUI to select on MDI:
halui.mode.is-mdi
will be true on MDi.
But If your using gladevcp you could use a button to invoke an MDI command to start the spindle:
linuxcnc.org/docs/2.7/html/gui/gladevcp....mand_on_button_press
or use a button to invoke a python script to start the spindle:
linuxcnc.org/docs/2.7/html/gui/gladevcp....gladevcp:programming
It's more to learn in the beginning but really opens up what you can do.
Chris M
8 years 11 months ago #101920 by nicokid
Hello Chris, thanks for your reply.
cmorley wrote: you could use HALUI to select on MDI:
halui.mode.is-mdi
Great, this works:
net net my-spindlespeed-mux <= halui.mode.is-mdi => mux2.%d.sel
This is fine if you do not load a file. But if I load a file, my slider (for set rpm speed) continues to have precedence over the M3 S20000 command. This is not fine.
cmorley wrote: But If your using gladevcp you could use a button to invoke an MDI command to start the spindle:
Chris M
This is interesting but you always have to press a button not just move the slider. It is not very user friendly.
I played a bit with python + gladevcp but I still have no great advantages over mdi_commands.
Thanks,
Nicola.
8 years 11 months ago #101925 by cmorley
If you load a file linuxcnc switches to auto mode but AXIS may switch back to MDI - use the status program to see what mode is currently running. Then you can try to cobble together some logic to work around the problem.
You can use the slider to invoke a python script too.
With python code you can do almost anything - this is how Gmoccapy and Gscreen interact with linuxcnc.
They are essentially just a non-standardly loaded gladevcp panel.
8 years 11 months ago - 8 years 11 months ago #102052 by nicokid
cmorley wrote: If you load a file linuxcnc switches to auto mode but AXIS may switch back to MDI - use the status program to see what mode is currently running. Then you can try to cobble together some logic to work around the problem.
Another interesting pin...
I joined things together and it seems that the system works.
In my-mill.hal:
setp lut5.0.function 0x1
net my-spindlespeed-is-mdi <= halui.mode.is-mdi => lut5.0.in-0
net my-spindlespeed-is-auto <= halui.mode.is-auto => lut5.0.in-1
net my-spindlespeed-lut <= lut5.0.out => mux2.0.sel
net spindle-cmd-rpm => mux2.0.in0
In postgui.hal:
net gvcp-spindlespeed <= gladevcp.scale_spindle_speed => mux2.0.in1
cmorley wrote: You can use the slider to invoke a python script too.
I like python. What worries me is having to handle hal pin both in hal files and in python scripts. Anyway, I'm sure I will try to play.
Thank you.
Nicola.
Last edit: 8 years 11 months ago by nicokid.
8 years 11 months ago #102298 by andypugh
I have a better idea ;-)
Use motion.spindle-on to control the mux.
Time to create page: 0.291 seconds
