external control help
  • alba00
  • Topic Author
  • New Member
  • New Member
8 years 9 months ago #104588 by alba00
external control help was created by alba00
Hi
I'm building a 3-axis mill I'm not very experienced I wanted to ask if it is possible with external commands (switches) to command the start1 that runs it in the default position and the start2 that runs the same program in a different position of the mill.
if this is possible and you can give some examples
I thank you for any reply
8 years 9 months ago #104599 by Todd Zuercher
Replied by Todd Zuercher on topic external control help
One way would be to use a couple of Halui MDI-commands.
  • alba00
  • Topic Author
  • New Member
  • New Member
8 years 9 months ago #104610 by alba00
Replied by alba00 on topic external control help
thanks for the answer I have a 5i25 + 7i76 you can give me a little example
  • alba00
  • Topic Author
  • New Member
  • New Member
8 years 9 months ago #104615 by alba00
the first switch works the second one does not work
loadrt and2 count=8
addf and2.0 servo-thread
addf and2.1 servo-thread
#addf and2.2 servo-thread
#addf and2.3 servo-thread
net program-start-btn and2.0.in0 <= hm2_5i25.0.7i76.0.0.input-04
net program-start-btn => halui.program.run
net program-start-btn => halui.mode.auto
net program-run-ok and2.0.in1 <= halui.mode.is-auto
net MDI-mode halui.mode.is-mdi
net program-start-btn1 and2.1.in0 <= hm2_5i25.0.7i76.0.0.input-08
net program-start-btn1 => halui.mdi-command-00
net program-run-ok and2.1.in1 <= halui.mode.is-auto
8 years 9 months ago - 8 years 9 months ago #104627 by Todd Zuercher
I think I would set up a work coordinate system for each work zone. G54 would be the default zone, and say G55 could be zone 2. (You could also get the same result using G10L20P0... to sift what ever work coordinate system your using.)
Then set up two Halui MDI-commands in your INI file. like this
[HALUI] MDI_COMMAND = G54 MDI_COMMAND = G55
Now this is the trickier part. You need your button presses to do two things, first trigger the pin halui.mdi-command-NN, then trigger the pin halui program.run.
I think the best way to do that would be with some edge components and one or2.
loadrt edge count=3 loadrt or2 count=1 addf edge.0 servo-thread addf edge.1 servo-thread addf edge.2 servo-thread addf or2.0 servo-thread setp edge.0.both false setp edge.1.both false setp edge.2.both false setp edge.0.in-edge true setp edge.1.in-edge false setp edge.2.in-edge false setp edge.0.out-width-ns 1000000 setp edge.1.out-width-ns 1000000 setp edge.2.out-width-ns 1000000 net program-start-btn1 <= hm2_5i25.0.7i76.0.0.input-04 => edge.1.in => or2.0.in0 net setg54 <= edge.1.out => halui.mdi-command-00 net program-start-btn2 <= hm2_5i25.0.7i76.0.0.input-08 => edge.2.in => or2.0.in1 net setg55 <= edge.2.out => halui.mdi-command-02 net run-or <= or2.0.out => edge.0.in net program-run <= edge.0.out => halui.program.run
The problem with this setup is that it breaks down if your G-code uses multiple work coordinate systems. I think This could be worked around with some O-subroutines, but it would be more complicated, and I'd have to think about quite a bit and do some testing.
PS the above hal code was just typed here and is untested, mostly just given as a possible example.
Last edit: 8 years 9 months ago by Todd Zuercher.
The following user(s) said Thank You: alba00
8 years 9 months ago #104630 by Todd Zuercher
Another possible solution is to choose and set the zone mostly in your G-code, with the setting of a global parameter by the halui.mdi-command selecting which zone is used. (the hal code part would be pretty much the same though) There are so many ways this could possibly be achieved. We just need to pick a direction you feel most comfortable with, then shake the bugs out as we go. There are possibilities using O-subs, joint offsets in hal, I am not sure what the "best" solution is. So for most of my Ideas have some kind of drawback, limitation or compications.
Time to create page: 0.536 seconds
