XHC-WHB04-4 simulation mode issue
3 years 2 months ago #277257 by Kasper-001
hello,
i was following this guide for the XHC-WHB04B pendant
forum.linuxcnc.org/24-hal-components/450...xhc-whb04b-4-pendant
and when i run the simulator in terminal it just doing this :
cnc@debian:~$ xhc-whb04b-6 -ue
init  starting in simulation mode
init  usb context ... ok
init  not waiting for device XHC-WHB04B-6 vendorId=0x10ce productId=0xeb93, will continue in 0s .......................................................................................................................................................
when i cancel it :
init  not waiting for device XHC-WHB04B-6 vendorId=0x10ce productId=0xeb93, will continue in 0s .......................................................................................................................................................^Ctermination requested upon signal number 2 ...
 ok
init  XHC-WHB04B-6 device found
HAL: ERROR: exit called before init
cnc@debian:~$
someting wrong whit the driver ?
runing Linuxcnc 2.10
3 years 2 months ago #277265 by Kasper-001
got it, image missing /media/kunena/emoticons/laughing.png
moved the   99-xhc-whb04b-6.rules   file to /etc/udev/rules.d/
github.com/machinekit/machinekit/blob/ma...9-xhc-whb04b-6.rules
The following user(s) said Thank You: tommylight, smc.collins
3 years 2 months ago #277276 by smc.collins
would you be so kind as to do a thorough write up on all of the exact steps ? so they can make a sticky out of it
3 years 2 months ago - 3 years 2 months ago #277367 by Kasper-001
if you have followed the guide  forum.linuxcnc.org/24-hal-components/450...xhc-whb04b-4-pendant
and still can´t get data flow from the pendant, is that the rule file may be missing
you have to inset the file -->  99-xhc-whb04b-6.rules  <--   into folder  /etc/udev/rules.d/
Last edit: 3 years 2 months ago by Kasper-001.
The following user(s) said Thank You: smc.collins
3 years 1 month ago #279974 by nighteagle
Hello,
very cool Video for the installation.
So i have the wired version of the Jog-Wheel but it works similar.
I have LinuxCNC 2.8.0 and have now the case that i can use the buttons and see all under HalConfiguration>Pins>whp>
If i watch the signals from jog-enable or jog-scale etc. all works... but the jog-counts not working.
I have test standalone with the command under halrun like you i the video. I see the counts change from 0 to positive or similar to negative. But it looks like my absolute counter is all time the same - in your video it goes up. Don't know is there a difference?
Have also start simaxis and also same problem i can not jog - but buttons works. I have use the example halfile like you in the video and have change only the lines with the double linked signals linuxcncn on start told me.
It is weird that i think the halfile is correct but the counts shows 0 all the time. First i thought it was the homing - my retrofit has now diassebled motors for testing - so no homing possible. But the simaxis is homed - and still same problem no jog counts.
Some idea what is missing - some hal link or similar? In the Standard axis.ini i have add only one line:
HALFILE = chinahandrad.hal
# ### Hal File xhc_whb04b_6.hal Example # # ###################################################################### # load pendant components # ###################################################################### loadusr -W xhc-whb04b-6 -H # ###################################################################### # pendant signal configuration # ###################################################################### # On/Off signals #net machine.is-on halui.machine.is-on whb.halui.machine.is-on net machine.is-on whb.halui.machine.is-on net pdnt.machine.on whb.halui.machine.on halui.machine.on net pdnt.machine.off whb.halui.machine.off halui.machine.off # program related signals net pdnt.program.is-idle whb.halui.program.is-idle halui.program.is-idle net pdnt.program.is-paused whb.halui.program.is-paused halui.program.is-paused net pdnt.program-is-running whb.halui.program.is-running halui.program.is-running net pdnt.program.resume whb.halui.program.resume halui.program.resume net pdnt.program.pause whb.halui.program.pause halui.program.pause net pdnt.program.run whb.halui.program.run halui.program.run net pdnt.program.stop whb.halui.program.stop halui.program.stop # machine mode related signals net pdnt.mode.auto whb.halui.mode.auto halui.mode.auto net pdnt.mode.manual whb.halui.mode.manual halui.mode.manual net pdnt.mode.mdi whb.halui.mode.mdi halui.mode.mdi net pdnt.mode.joint whb.halui.mode.joint halui.mode.joint net pdnt.mode.teleop whb.halui.mode.teleop halui.mode.teleop net pdnt.mode.is-auto halui.mode.is-auto whb.halui.mode.is-auto net pdnt.mode.is-manual halui.mode.is-manual whb.halui.mode.is-manual #net pdnt.mode.is-mdi halui.mode.is-mdi whb.halui.mode.is-mdi# net pdnt.mode.is-mdi whb.halui.mode.is-mdi net pdnt.mode.is-joint halui.mode.is-joint whb.halui.mode.is-joint net pdnt.mode.is-teleop halui.mode.is-teleop whb.halui.mode.is-teleop # "is-homed" axis signal for allowing pendant when machine is not homed #net pdnt.axis.X.is-homed halui.joint.0.is-homed whb.halui.joint.x.is-homed net pdnt.axis.X.is-homed whb.halui.joint.x.is-homed #net pdnt.axis.Y.is-homed halui.joint.1.is-homed whb.halui.joint.y.is-homed net pdnt.axis.Y.is-homed whb.halui.joint.y.is-homed #net pdnt.axis.Z.is-homed halui.joint.2.is-homed whb.halui.joint.z.is-homed net pdnt.axis.Z.is-homed whb.halui.joint.z.is-homed # "selected axis" signals #net pdnt.axis.X.select whb.halui.axis.x.select halui.axis.x.select net pdnt.axis.X.select whb.halui.axis.x.select #net pdnt.axis.y.select whb.halui.axis.y.select halui.axis.y.select net pdnt.axis.y.select whb.halui.axis.y.select #net pdnt.axis.Z.select whb.halui.axis.z.select halui.axis.z.select net pdnt.axis.Z.select whb.halui.axis.z.select net pdnt.axis.x.jog-scale whb.axis.x.jog-scale axis.x.jog-scale net pdnt.axis.y.jog-scale whb.axis.y.jog-scale axis.y.jog-scale net pdnt.axis.z.jog-scale whb.axis.z.jog-scale axis.z.jog-scale net pdnt.axis.x.jog-counts whb.axis.x.jog-counts axis.x.jog-counts net pdnt.axis.y.jog-counts whb.axis.y.jog-counts axis.y.jog-counts net pdnt.axis.z.jog-counts whb.axis.z.jog-counts axis.z.jog-counts net pdnt.axis.x.jog-enable whb.axis.x.jog-enable axis.x.jog-enable net pdnt.axis.y.jog-enable whb.axis.y.jog-enable axis.y.jog-enable net pdnt.axis.z.jog-enable whb.axis.z.jog-enable axis.z.jog-enable net pdnt.axis.x.jog-vel-mode whb.axis.x.jog-vel-mode axis.x.jog-vel-mode net pdnt.axis.y.jog-vel-mode whb.axis.y.jog-vel-mode axis.y.jog-vel-mode net pdnt.axis.z.jog-vel-mode whb.axis.z.jog-vel-mode axis.z.jog-vel-mode # macro buttons to MDI commands #net pdnt.macro-1 whb.button.macro-1 halui.mdi-command-01 # use MDI command from main.ini #net pdnt.macro-2 whb.button.macro-2 halui.mdi-command-02 # use MDI command from main.ini or used for Hardcoded lube on/off net pdnt.reserved.for.spindle+ whb.button.macro-3 # Hardcoded for spindle+ whb.halui.spindle.increase net pdnt.reserved.for.spindle- whb.button.macro-4 # Hardcoded for spindle- whb.halui.spindle.decrease #net pdnt.macro-5 whb.button.macro-5 halui.mdi-command-05 # use MDI command from main.ini #net pdnt.macro-6 whb.button.macro-6 halui.mdi-command-06 # use MDI command from main.ini #net pdnt.macro-7 whb.button.macro-7 halui.mdi-command-07 # use MDI command from main.ini net pdnt.reserved.for.spindle.dir whb.button.macro-8 # Hardcoded for spindle direction inside pendant #net pdnt.macro-9 whb.button.macro-9 halui.mdi-command-09 # use MDI command from main.ini net pdnt.reserved.for.ABS-REL whb.button.macro-10 # Hardcoded for swap Dro Relative/Absolue #net pdnt.macro-14 whb.button.macro-14 halui.mdi-command-14 # use MDI command from main.ini net pdnt.reserved.for.flood whb.button.macro-15 # Hardcoded for halui.flood on/off net pdnt.reserved.for.mist whb.button.macro-16 # Hardcoded for halui.mist on/off #net pdnt.macro.11 whb.button.macro-11 halui.mdi-command-11 # use MDI command from main.ini #net pdnt.macro.12 whb.button.macro-12 halui.mdi-command-12 # use MDI command from main.ini #net pdnt.macro.13 whb.button.macro-13 halui.mdi-command-13 # use MDI command from main.ini # flood and mist toggle signals net pdnt.flood.is-on whb.halui.flood.is-on halui.flood.is-on #return signal is on or off net pdnt.flood.off whb.halui.flood.off halui.flood.off #reserved whb.button.macro-15 net pdnt.flood.on whb.halui.flood.on halui.flood.on #reserved whb.button.macro-15 net pdnt.mist.is-on whb.halui.mist.is-on halui.mist.is-on #return signal is on or off net pdnt.mist.off whb.halui.mist.off halui.mist.off #reserved whb.button.macro-16 net pdnt.mist.on whb.halui.mist.on halui.mist.on #reserved whb.button.macro-16 #net pdnt.lube.is-on whb.halui.lube.is-on halui.lube.is-on #return signal is on or off #net pdnt.lube.off whb.halui.lube.off halui.lube.off #reserved whb.button.macro-2 #net pdnt.lube.on whb.halui.lube.on halui.lube.on #reserved whb.button.macro-2 # default function button signals net pdnt.button.m-home whb.button.m-home halui.home-all # Homeing use built-in halui home all #net pdnt.button.safe-z whb.button.safe-z halui.mdi-command-03 # Safe-z use MDI command from main.ini #net pdnt.button.w-home whb.button.w-home halui.mdi-command-04 # Unpark use MDI command from main.ini #net pdnt.button.probe-z whb.button.probe-z halui.mdi-command-08 # Probe-Z use MDI command from main.ini # unused, just exposes pendant internal status or as basic button net pdnt.mode-lead whb.halui.feed.selected-lead net pdnt.mode-mpg-feed whb.halui.feed.selected-mpg-feed net pdnt.mode-continuous whb.halui.feed.selected-continuous net pdnt.mode-step whb.halui.feed.selected-step net pdnt.button.mode-mpg whb.button.mode-continuous net pdnt.button.mode-step whb.button.mode-step net pdnt.button.fn whb.button.fn net pdnt.button.reset whb.button.reset net pdnt.button.stop whb.button.stop net pdnt.button.start-pause whb.button.start-pause net pdnt.button.s-on-off whb.button.s-on-off net pdnt.button.spindle-plus whb.button.spindle-plus net pdnt.button.spindle-minus whb.button.spindle-minus net pdnt.button.feed-plus whb.button.feed-plus net pdnt.button.feed-minus whb.button.feed-minus # spindle related signals #net pdnt.spindle.is-on whb.halui.spindle.is-on spindle.0.on net pdnt.spindle.is-on whb.halui.spindle.is-on net pdnt.spindle.start whb.halui.spindle.start halui.spindle.0.start #net pdnt.spindle.stop whb.halui.spindle.stop halui.spindle.0.stop net pdnt.spindle.stop whb.halui.spindle.stop #net pdnt.spindle.forward whb.halui.spindle.forward halui.spindle.0.forward net pdnt.spindle.forward whb.halui.spindle.forward #net pdnt.spindle.reverse whb.halui.spindle.reverse halui.spindle.0.reverse net pdnt.spindle.reverse whb.halui.spindle.reverse net pdnt.spindle.increase whb.halui.spindle.increase halui.spindle.0.increase # reserved whb.button.macro-3 net pdnt.spindle.decrease whb.halui.spindle.decrease halui.spindle.0.decrease # reserved whb.button.macro-4 #net pdnt.spindle-speed-abs whb.halui.spindle-speed-cmd spindle.0.speed-out-abs # speed cmd from motion in rpm absolue net pdnt.spindle-speed-abs whb.halui.spindle-speed-cmd  # speed cmd from motion in rpm absolue # spindle speed override signals net pdnt.spindle-override.scale whb.halui.spindle-override.scale halui.spindle.0.override.scale # needed for both spindle+/- and spindleoverride+/- button net pdnt.spindle.override.value halui.spindle.0.override.value whb.halui.spindle-override.value # GUI feed rate related signals net pdnt.spindle.override.increase whb.halui.spindle-override.increase halui.spindle.0.override.increase net pdnt.spindle.override.decrease whb.halui.spindle-override.decrease halui.spindle.0.override.decrease # GUI feed rate related signals can be used when program is running moving GUI slider net pdnt.feed-override.scale whb.halui.feed-override.scale halui.feed-override.scale # needed for both FeedOverride+/- and rotary knob button net pdnt.max-velocity.value whb.halui.max-velocity.value halui.max-velocity.value # needed for Mpg mode : button feed position% * max-velocity = Mpg feedrate # take feed override min/max values from/to the GUI net pdnt.feed-override.value halui.feed-override.value whb.halui.feed-override.value # GUI feed rate related signals net pdnt.feed-override.increase whb.halui.feed-override.increase halui.feed-override.increase net pdnt.feed-override.decrease whb.halui.feed-override.decrease halui.feed-override.decrease # axis position related signals feedback net pdnt.axis.x.pos-feedback halui.axis.x.pos-feedback whb.halui.axis.x.pos-feedback net pdnt.axis.y.pos-feedback halui.axis.y.pos-feedback whb.halui.axis.y.pos-feedback net pdnt.axis.z.pos-feedback halui.axis.z.pos-feedback whb.halui.axis.z.pos-feedback # axis position related signals relative net pdnt.axis.x.pos-relative halui.axis.x.pos-relative whb.halui.axis.x.pos-relative net pdnt.axis.y.pos-relative halui.axis.y.pos-relative whb.halui.axis.y.pos-relative net pdnt.axis.z.pos-relative halui.axis.z.pos-relative whb.halui.axis.z.pos-relative
3 years 1 month ago #280006 by nighteagle
Have found it:
change to:
#net machine.is-on whb.halui.machine.is-on
Error say is linked already to halui.machine.is-on
And in the basic.hal file on an long searching - there was the double link. Removed it and Now it is working.
Time to create page: 0.335 seconds
