- Thank you received: 3
It seems to work for me.Maybe have a look at the 'joint.N.unlock' pins:
linuxcnc.org/docs/html/man/man9/motion.9...OINT%20unlock%20pins
I can only control the brake with G0 moves.The intended use is for indexing rotaries as described in this section:
linuxcnc.org/docs/stable/html/config/ini...:ini:sec:axis-letter
If you need more than just G0 moves then you would likely need to make something up in HAL.
