OT-CNC,
Probably the most useful page of the pdf w/ the link below is page 3, which has my notes of what I decided to do w/ PCB801.
drive.google.com/file/d/0ByHpuoFMRAsDeDh...bDQ/view?usp=sharing
Trying to explain it, I removed 2 of the 3 relays (ice cub style relays) on the top of the PCB801 board. The one that I left, K3 is used to trigger K2, which is a Solid State Relay (SSR) located UNDERNEATH the PCB801 and this SSR is what allows 120Vac power to goto the transformer (if I recall correctly) and ultimately power the West Amp servo amplifiers. They do this on P6, which I would have left attached.
The KEY here is that on P5 I disconnected the COM (pin 1) and +24Vdc (pin 2) and then connected the mesa to pins P3 1 and 2. This is the ENABLE for the servo axes and I used a standard OUTPUT from the 7i77.
I also left the auto/manual switch (p4) connected. That allows you to turn the switch to manual and NOT power the servo's. I never use it, though. Maybe once...
Also, I rewired P7 to the machines RESET button and Pilot light that is powered by the output from the mesa. Hmmm, I noticed that my pilot wasn't always working, I bet that output from the mesa (or something else) is an issue, need to look into that.
The main thing here is that the mesa has sourcing OUTPUTS while the PCB801 was designed for Sinking outputs. That's why they have +24VDC hooked up on P5 pin 2. Eliminate that and run the relays 'backwards' so to speak...
Holler with questions, think i have an idea of what and why I did it, but didn't document it that well.
Mark
