---Warning : IF using this tutorial, NEVER edit the /etc/network/interfaces file as mentioned in the official documents, using BOTH causes a lot of issues, so use this OR the other, never both!!! ---
--This is valid for all Linux versions that use network manager, like Debian Wheezy or Jessie or Stretch, Ubuntu, Linux Mint etc.
--Mesa card should be wired directly to the PC, not over a switch or HUB or router.
====Network setup for mesa cards: ======
- left click on the network manager on the bottom right side or upper right side near the clock and volume.
- choose "edit connections"
- double click on the network you want to edit ( usually "wired connection X")
- click on the "IPv4 settings" tab
- choose "manual" on the "method" drop down menu
- click on "add"
- write the address as 10.10.10.11
never use 10.10.10.1 or 10.10.10.10 for the above
- netmask should be left as is ( usually 8 )
- click on "routes"
- click on "use this connection for resources on its network"
Save, close, left click on the network manager and click on the "wired connection X", it should take about 3 seconds to reconnect.
Now open a terminal and do Ping 10.10.10.10, you should get normal reply form the Mesa card. If you do not get a reply, double check your settings.
To check the Mesa card configuration, in terminal enter :
mesaflash --addr 10.10.10.10 --device=ETHER --readhmid
There should be a lot of info in the terminal about the card and the available stepgens, PWM's, IO's, etc
