Bad Day...
5 years 4 months ago - 5 years 4 months ago #213345 by Cam_Haug
Tried to hook up an MPG, think I managed to get 24V on the 5v side image missing /media/kunena/emoticons/sad.png
Last edit: 5 years 4 months ago by Cam_Haug.
5 years 4 months ago - 5 years 4 months ago #213348 by Cam_Haug
Replied by Cam_Haug on topic Bad Day...
For context, it is my shiny new Mesa 7i76e, MPG internally shorted, killed the on board 5v, tried to power up with external 5v and blew that diode....
Anyone know the specs of the transistor and the little surface mount fuse?
Should I chuck it in the bin?
5 years 4 months ago #213354 by PCW
Replied by PCW on topic Bad Day...
The 5V protection Zener is a 3SMAJ5919B-TP
The 5V connector PTC is a MF-NSMF200-2
If the Zener shorted out and protected the rest of the 5V circuitry,
simply removing the Zener may get you back running.
5 years 4 months ago - 5 years 4 months ago #213414 by Cam_Haug
Interesting - so despite the smoke the PTC is still closed
I removed the Zener and fired up with 5v and I can communicate. Giving 24v to field power then allows me to start linux CNC but I get a remote error (29) reported of under voltage - will this be a stored or current error?
5 years 4 months ago #213416 by Cam_Haug
Further testing shows that i have:
Working:
Stepper Drivers
Spindle Encoder
Non Working:
Any Field Voltage IO
Spindle Control
I think the non working stuff is the low voltage bein reported - I can see instead of 5v there it is flicking between .2 and 0v
5 years 4 months ago #213418 by Cam_Haug
I was looking at the opto isolated Circuit with the weird low readings so ignore that
The A4447 regulator powering the pic chip and optos outputs 3.3v so that looks good.
The A4447 regulator that I assume is used for the 5V power supply (U1) has 5 volts at the output (from the external power supply), this seems to push 4.4v to the input...i assume it is either meant to do that or the chip is blown?
What happens if i try and power up without the Zener at CR17? I cant find any other signs of damage so not sure what is going on :( Can i just replace that with any 5.6v zener?
appreciate the pointers :)
Moderators: PCW, jmelson
Time to create page: 0.195 seconds
