7i77 burned, cause?
4 years 10 months ago #228436 by danilom
7i77 burned, cause? was created by danilom
On a retrofited Biesse I have a situation where both 7i71 cards burned out all same chips are damaged on both. 7i77 and 7i70 cards are fully functional.
7i71 outputs are wired to factory plc mosfet outputs. Two cards have nothing in common except 24v power supply that they also share with 7i70 which are ok.
4 years 10 months ago - 4 years 10 months ago #228437 by PCW
Replied by PCW on topic 7i77 burned, cause?
If you had multiple cards damaged at once that suggest's
some common issue (the 24V power?)
Note that a 7I70 (an input only card) will withstand up to 50V on its field power
input but the driver chips on a 7I71 will be damaged at about 36V
Last edit: 4 years 10 months ago by PCW.
4 years 10 months ago #228439 by danilom
Replied by danilom on topic 7i77 burned, cause?
Could it be that some voltage or short came back on some of output pins. Manually applying 24v on outputs activates all plc outputs and all solenoids activate
4 years 10 months ago #228451 by tommylight
Replied by tommylight on topic 7i77 burned, cause?
That looks like high voltage arcing across the chips, especially the middle left one.
4 years 10 months ago #228464 by bevins
Replied by bevins on topic 7i77 burned, cause?
IT looks like you connected your mesa outputs trying to drive the mosfets on the Biesse machine directly.
4 years 10 months ago #228467 by danilom
This has been in use for 4 years now
Moderators: PCW, jmelson
Time to create page: 0.445 seconds
