Hi folks,
I'm trying to set up a mesa 7c81 with 7i77 board and I'm afraid I may have messed up the board. Hopefully somebody can guide.
I'm using a 7c81 with raspberry Pi 4 /8G (I purchased this unit a couple years ago but I'm only getting around to setting it up now)
Linuxcnc 2.8.1 (linuxcnc-2.8.1-pi4.zip)
Power is supplied to the 7i77 via the 25pin connector from the 7c81 and field power (24v) on the 7i77 is connected.
I tried creating a couple of configs with pncconf and had a problem
hm2/hm2_7c81.0: config.num_encoder=6, but only 1 available
From some research it seems like I needed to flash the 7c81 for the 7i77 (maybe I went wrong here? )
From the mesa page I got the support software
www.mesanet.com/software/parallel/7c81.zip
Got mesaflash version 3.4.7 from git (and did make) but unfortunately I forgot to directly address the newly downloaded mesaflash and the version that ran was actually 3.4.6
I did:
pi@apeiron:~/linuxcnc/7c81/configs/hostmot2 $ mesaflash --device 7C81 --spi --addr /dev/spidev0.0 --write 7c81_7i77x2d.bit
unable to set bpw32, fallback to bpw8
Checking file... OK
File type: Xilinx bit file
Boot sector OK
FLASH memory sectors to write: 6, max sectors in area: 32
Erasing FLASH memory sectors starting from 0x200000...
|EEEEEE
Programming FLASH memory sectors starting from 0x200000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
Boot sector OK
Verifying FLASH memory sectors starting from 0x200000...
|V0 timeout waiting for SPI data
Error at 0x203D4B expected: 0x0 but read: 0x7F
Unexpected cookie at 0100..0110:
0fff0fff 0fff0fff 0fff0fff
No 7C81 board found
Even after power cycle same issue - unreadable when it worked before. For example this used to work:
mesaflash --device 7C81 --spi --addr /dev/spidev0.0 --readhmid
9fff1fff 1fff1fff 1fff1fff
No 7C81 board found
(I'm attaching the --readhmid output from when it worked.)
The lights on the board I think show that it is on the main bootfile and not the fallback. (init isn't blinking)
It seems to me like I've messed up the 7c81 and perhaps the only fix is through the jtag port? (not that I know how to do that).
I'd appreciate any guidance you might have.
