6i24-25 with 7i53: bitfile ?
3 years 2 months ago #276987 by EGR
Hello Everyone,
I'm an amateur with irregular time to work on my future CNC machine, nevertheless I'm learning a lot through reading posts of this forum, thanks a lot !
I would like to use a 6i24_25 only (for the time being) connected to a 7i53 but I didn't find any specific bitfile, therefor my current understanding would be to:
- select the 6i24 PCI bus clock to 5i24 compatible
- to use MESAFLASH with SVST8_8IM2 and disabling everything except encoders during pncconf ?
and it should do the trick ?
Thanks a lot for your feedback.
Have all a great weekend.
Emeric
3 years 2 months ago #277020 by PCW
Replied by PCW on topic 6i24-25 with 7i53: bitfile ?
You would need firmware specifically made for the 7I53
(and whatever other daughter cards you need)
The following user(s) said Thank You: EGR
3 years 2 months ago #277317 by EGR
Replied by EGR on topic 6i24-25 with 7i53: bitfile ?
Thanks a lot for the info !
By any chance, would you know where to look for additional infos ? Any documentation available somewhere ?
Again, thank you very much for your time.
Emeric
3 years 2 months ago #277330 by PCW
Do you already have the 6I24 and 7I53?
What are you trying to control?
3 years 2 months ago #277513 by EGR
I already have both boards (initially from another collaborative project which is stopped), initial aim is to connect at least 4 encoders for my prototype CNC. (I'm not attempting to build a production machine but more, for the time being, to learn & understand, let's see where it goes)
I found the below tutorial
tom-itx.no-ip.biz:81/~webpage/emc/xilinx...14_install_index.php
which seems to be a good starting point.
E.
3 years 2 months ago #277802 by EGR
Hello,
I was naively thinking it should be easy to create a dedicated bif file but I'm block since the beginning since I cannot find any source for the 7i53.
Would anyone has any suggestion to start with ?
Thanks a lot
Emeric
Moderators: PCW, jmelson
Time to create page: 0.397 seconds
