Out of inputs
2 years 6 months ago #299452 by COlger81
Out of inputs was created by COlger81
I have a 7i92m, 7i77, and a 7i72. All 32 inputs are in use and i need 3 more digital inputs. The smart serial rs422 port on the 7i77 is used by the 7i72. What is the best way to achieve this?
2 years 6 months ago #299457 by tommylight
Replied by tommylight on topic Out of inputs
IDC26 connector on 7i92 has 17 more IO, but those are very sensitive so care must be taken for wiring and signal shaping.
Using voltage dividers (simple 2 resistor thingy) you can use those for anything you need.
Or get a cheap BOB and IDC26-DB25 connector, but that limits to only 5 inputs.
The following user(s) said Thank You: Cant do this anymore bye all
2 years 6 months ago #299458 by Cant do this anymore bye all
The 2nd port on the 7i92 can be used.
A opto isolator board, something found on eBay or AliExpress or a dozen places, can be used to provide voltage translation.
2 years 6 months ago #299461 by COlger81
Replied by COlger81 on topic Out of inputs
Is there a mesa option to achieve this? Would it be possible to use a spare encoder input on the 7i77?
2 years 6 months ago #299462 by COlger81
1 of the 3 inputs needed will be used for a prox sensor to home ATC turret.
2 years 6 months ago - 2 years 6 months ago #299464 by PCW
Replied by PCW on topic Out of inputs
Yes, you can use spare encoder pins as general purpose inputs.
They will work with 5V signals if set to single ended mode.
The encoder inputs have a 2K pullup resistor to 5V (so will work
with NPN proximity switches) The single ended encoder inputs
are safe to +12 and -7V.
The pin names will be:
hm2_7i92.0.encoder.0x.input-a
hm2_7i92.0.encoder.0x.input-b
hm2_7i92.0.encoder.0x.input-index
Last edit: 2 years 6 months ago by PCW.
Moderators: PCW, jmelson
Time to create page: 0.213 seconds
