Yes of course, they are attached in the Elumatec SBZ130/01 retrofit page, not sure if i updated to the latest version so you might have to go through quite a long topic to check, although might not need the latest as the encoders were the first thing working, after the initial wiring. The latest should also have the toolchanger with grayscale feedback.
Pretty sure Tommylight has some example files using SSI feedback (which is very similar at the HAL level)
