Thanks Peter — that’s very helpful.
That aligns well with my use case. Since the IL-1000 is only ~10 Hz bandwidth and Y motion is intentionally slow, trading loop bandwidth for higher effective resolution via low-pass filtering sounds ideal for stable stand-off control.
Given that, THCAD-2 looks like the right solution for the current phase, especially with it coming back in stock shortly.
For any future higher-speed sensor upgrades, I’ll revisit true ADC options like the 7i87 if needed — but for now THCAD-2 + filtering seems well matched to the application.
In addition, I will need extra isolated digital I/O for valves, interlocks, and machine signals. I was looking at the 7I84U isolated remote field I/O card (sourcing/sinking outputs), but it currently shows as out of stock. My preference is to stay within the Mesa ecosystem rather than using generic BOBs, to keep things robust and well-supported in an electrically noisy environment.
If you have any guidance on availability of the 7I84U, or alternative Mesa smart-serial I/O options that integrate well with 7i96S for isolated field I/O, I’d really appreciate your recommendation.
Thanks again for the detailed clarification.
