It depends on what type of encoder it is. The 4-channel commutation + quadrature type can be used with a normal encoder counter for position and the bldc HAL component can use the 4-channel commutation signals for motor commutation.toolmaker69 wrote: 1. I thought I needed some kind of kit to translate the Fanuc encoder output to something the Mesa card would understand. Is that not correct? Or is that just when using non-Fanuc amps?
You should certainly not run them with a velocity-mode drive that expects tacho feedback, but if you had that then you wouldn't be asking the question, I assume. If the motor speed / position loop is closed some other way (typically an encoder) then you can ignore the tacho.2. I thought one should never run tacho-generator servos without tacho feedback. I have lots of tacho-generator servo motors around. Could I put them on the rotary tables, or even use them for a 3 axis mill without using the tachogenerators?
That slightly depends on which drives, and how many PWM channels you need. I am terrible with names and this is a new thread, are you the chap who already knows that he needs 6 PWM channels?3. If I was ignorantly reading threads that were based on just using the motors and not the Fanuc drives, then is it pretty easy to just find the PWM inputs on the drives and run the machine from there?
andypugh wrote:
"... then is it pretty easy to just find the PWM inputs on the drives and run the machine from there?"
