Encoder KOYO TRDA-20R1N2500VD arrived from ebay. New open box unit.
Changed jumpers W10,W11 and W13 to the differential position. Wired per Mesa 7i76e document for TB3 encoder section.
Spun the encoder shaft by hand see nothing that indicates its working
james@LinuxCnc:~$ halcmd show pin hm2_7i76e.0.encoder
Component Pins:
Owner Type Dir Value Name
26 s32 OUT 0 hm2_7i76e.0.encoder.00.count
26 s32 OUT 0 hm2_7i76e.0.encoder.00.count-latched
26 bit I/O FALSE hm2_7i76e.0.encoder.00.index-enable <=> spindle-index-enable
26 bit OUT TRUE hm2_7i76e.0.encoder.00.input-a
26 bit OUT TRUE hm2_7i76e.0.encoder.00.input-b
26 bit OUT FALSE hm2_7i76e.0.encoder.00.input-index
26 bit IN FALSE hm2_7i76e.0.encoder.00.latch-enable
26 bit IN FALSE hm2_7i76e.0.encoder.00.latch-polarity
26 float OUT 0 hm2_7i76e.0.encoder.00.position ==> spindle-revs
26 float OUT 0 hm2_7i76e.0.encoder.00.position-latched
26 bit OUT FALSE hm2_7i76e.0.encoder.00.quad-error
26 bit IN FALSE hm2_7i76e.0.encoder.00.quad-error-enable
26 s32 OUT 0 hm2_7i76e.0.encoder.00.rawcounts
26 s32 OUT 0 hm2_7i76e.0.encoder.00.rawlatch
26 bit IN FALSE hm2_7i76e.0.encoder.00.reset
26 float OUT 0 hm2_7i76e.0.encoder.00.velocity ==> spindle-vel-fb-rps
26 float OUT 0 hm2_7i76e.0.encoder.00.velocity-rpm ==> spindle-vel-fb-rpm
26 bit IN FALSE hm2_7i76e.0.encoder.hires-timestamp
26 u32 IN 0x017D7840 hm2_7i76e.0.encoder.sample-frequency
26 s32 IN -1 hm2_7i76e.0.encoder.timer-number
Tried setting signal spindle-index-enabale still nothing. I expected to see at least hm2_7i76e.0.encoder.00.count to go up.
Any debug suggestions.
jim
