I'm having issues with the spindle stopped signal from the VFD on a Biesse Rover 322 retrofit.
VFD is a Commander CD-series, with a spindle stopped signal configured on Terminal A0 (see attachment for details). I suspect the output to be bruned, as it gives 24V out, no matter the state of the VFD (ready, accelerating, at speeds, decelerating, stopped).
Original config of the machine uses this output for spindle stopped signal, and RS-485 for speed and other commands. As the serial link uses ANSI x3.28 (not modbus) I've not been able to get it running with LinuxCNC. Hence I've been left with analog control of the VFD.
Reading the 0-10 volt output from the VFD with analog in on MESA hardware gives me 2.3 to 6.1 volts with lots of noise. Tried several different cables and shielding strategies without luck.
Would appreciate any and all input on following:
- Has there been any work done on implementing ANSI x3.28 over RS-485?
- What's involved in writing a driver to get the serial interface working via USB dongle?
- Can the output terminal on the VFD be repaired?
- How to reliably read the 0-10 volt speed output from VFD
Kind regards TomE.
