flood fill algorithm
3 years 5 months ago #270970 by clive
flood fill algorithm was created by clive
I have done a brief internet search looking for a flood-fill algorithm. That is an algorithm to clear/mill and arbitrarily shaped region on a woodblock.I know there has to be commercial tools that do this but, for the moment, I'd like to incorporate it into my own CAM/G-Code tool.Can anyone point me to some pseudo code please.https://www.royalacademy.org.uk/article/felix-vallotton-beginners-guide
3 years 5 months ago #270975 by tommylight
Replied by tommylight on topic flood fill algorithm
Why the link?
Does it have to do with the question?
3 years 5 months ago #271028 by clive
Replied by clive on topic flood fill algorithm
It is the kind of carving I want to do. Vallotton made quite remarkable woodblock prints. Very simple, black and white blocks. In his case hand carved.
A basic pixel image flood fill algorithm is easy but for a CNC cut with a finite tool size, it seems much harder.
Maybe I should just explore inkscape ?
3 years 5 months ago - 3 years 5 months ago #271036 by clive
Is image-to-gcode already installed alongside LinuxCNC ? Can it be found as a separate program ?
I found this  stand alone  version on GitHub from five years ago but it is not in Python3 and will take a fair amount of time to clean up.
Last edit: 3 years 5 months ago by clive.
3 years 5 months ago #271043 by tommylight
Try this, i use it sometimes and i like it better than image2gcode.
It is derived from image2gcode, as it states at the top of the code, though.
www.scorchworks.com/Dmap2gcode/dmap2gcode.html
The following user(s) said Thank You: clive
3 years 5 months ago #271063 by clive
The dmapto2gcode looks to be what I should run.
The code uses a Python module called tkinter which isn't in my system. I installed it using pip but dmapto2gcode still can't find the module to import.
I'm not a regular Python user so figuring out where modules might reside is a puzzle.
Time to create page: 0.177 seconds
