5 axis tool offset
1 month 4 weeks ago #349299 by RLA
5 axis tool offset was created by RLA
I have a 5 axis homemade machine xyzab...I get gcode from CNCToolkit in Gmax....works pretty well other than tool offset...My linuxcnc is set up in Trivkins...My questions..  I believe there is a 5 axis configuration...
Is it very involved to switch?
Can tool diameter offsets be used?
Would it be better to try and modify CNCToolkit post to use tool offset?
I am going off a surface...x y offsets I can draw...the biggest issue is allowing for tool diameter in adjusting z axis for b movents.
Thanks for any help!!
Rick
1 month 4 weeks ago #349301 by Aciera
Replied by Aciera on topic 5 axis tool offset
There are several.
So what exactly do you mean by 'xyzab'? That can mean a few different kinematics.
1 month 4 weeks ago #349309 by RLA
Replied by RLA on topic 5 axis tool offset
Like pic attached..
1 month 4 weeks ago #349319 by Aciera
For this geometry there is this sim config in the current development branch:
github.com/LinuxCNC/linuxcnc/tree/master...ndle-rotary-nutating
I would suggest you have look at that before you start looking at changing over from trivkins.
You should also be able to install the kinematics component on version 2.9 using 'halcompile' (for which you may need to install the linuxcnc-dev package). The component can also be found here:
github.com/Sigma1912/LinuxCNC_Demo_Confi...ary/xyzacb-snrtr_twp
For your case, you would set the nutation angle to 90° and ignore the C axis. TCP will work just fine but the TWP feature will currently only work for the head rotation.
1 month 4 weeks ago #349321 by RLA
So IF I were able to get tool offset for 5 axis in CNCToolkit and run in trivkins.....would not having the TWP give same results?
Thanks for help here...I am a little over my head here but need to learn..
1 month 4 weeks ago #349325 by Aciera
TWP is the 'tilted work plane' feature, you are likely after the TCP mode that keeps tool tip position stationary when the tool orientation and offsets change.
If your CAM is capable of handling tool offsets then you can keep using trivkins.
Time to create page: 0.069 seconds
