Nothing to do .....
today I downloaded new iso ubuntu10.04 + linuxcnc2.5 .... verify with md5sum (ok) ... installed ... run stepconf 1 time with parallel port ok! Using software source and synaptic I upgrade to 2.6.10 ... re.run the pc.... run stepconf 1 time with parallel port ok! ... re.run the pc ....Using software source and synaptic I upgrade to 2.7.1 ....re.run the pc.... run stepconf 1 time with parallel port ok! ... run PnConfig ... the same NOT APPEAR TB5 CONNECTOR ....
Than I downloaded 5i25.zip from this
store.mesanet.com/index.php?route=product/product&product_id=55
... wit sudo nautilus I've create 5i25 folder in /lib/firmware/hm2 with only 5i25_7i77x2.xml and .pin file .... sudo apt-get install mesaflash ....
sudo mesaflash --device 5i25 --write /home/k1/5i25/configs/hostmot2/5i25_7i77x2.bit
sudo mesaflash --device 5i25 --reload
sudo mesaflash --device 5i25 --verify /home/k1/5i25/configs/hostmot2/5i25_7i77x2.bit
all ok ...... try launch pnconfig again whit 5i25 selection .... only 7i77x2 config is possible .... accept ...same result not ss0 and ss1 windows. :evil: :evil: :evil:
