Help wanted - configuring 7i73
9 years 6 months ago #92085 by rotwang
Configuration is 5i25-7i76-7i73
Pncconf accepts a 7i73 on SmartSerial2 but only offers a list of pin numbers as inputs and outputs plus the red CR1 led (communications watchdog) stays lit.
If I just ignore this and go through the rest of the configuration, save it, and then launch linuxcnc with this configuration then CR2 starts blinking like it should.
I've set the jumpers on the 7i73 for LCD+Keypad and the LCD (QC2004A) initialises correctly with cursor at left of row1.
I've tried "loadrt lcd fmt_strings=""Linuxcnc"" " but nothing appears on screen, and I don't seem to have any HAL pins that look relevant.
Has anybody configured this setup and what did you have to do.
If you need more information just ask.
Roger
I've already tried forum search and wiki search without success.
9 years 6 months ago #92093 by PCW
Replied by PCW on topic Help wanted - configuring 7i73
Do you have all the LCD comp connections wired and lcd function addf'ed in the hal file?
9 years 6 months ago #92095 by rotwang
Quite possibly not, if I could find a guide to configuring the 7i73, I'd be able to ask more intelligent questions.
Let me do some checking on the lcd function and comp and I'll see if I can make some progress.
Would I be correct to assume that pncconf knows very little about the 7i73 and its up to me to sort out keyboard matrix pins etc.
Roger
9 years 6 months ago #92100 by andypugh
rotwang wrote: Would I be correct to assume that pncconf knows very little about the 7i73 and its up to me to sort out keyboard matrix pins etc.
Yes, I think that seems like a fair bet.
9 years 6 months ago #92101 by andypugh
You won't see many HAL pins with just format_strings="LinuxCNC"
You should see:
4 float IN 0 lcd.00.contrast
4 u32 OUT 0x00000000 lcd.00.out
4 u32 IN 0x00000000 lcd.00.page_num
You need to:
addf lcd servo-thread net chars lcd.00.out hm2_5i25.0.7i73.0.2.lcd
(I am completely guessing the name of the 7i73 LCD input pin)
9 years 6 months ago #92102 by rotwang
I'll be trying that out tomorrow morning, just have to remember that re-running pncconf wipes out my .hal file, so |I need to put this stuff in custom.hal.
Sigh.
Roger
Time to create page: 0.109 seconds
