Adding 7i73 to working setup 5i15 7i77 7i84
9 years 3 months ago #95687 by danilom
Hello all
I have a working config with 5i25 with one 7i77 connected to it and 7i84 connected to the 7i77 RS422 pins
is there a way to connect 7i73 pendant interface to this configuration without adding 7i74 8 channel RS422 interface card?
9 years 3 months ago - 9 years 3 months ago #95690 by PCW
Its awkward to add just one additional RS-422 port
I can be done with a single external chip (a SP491 for example)
or using a Mesa 485X1 TTL to RS-422/485 adapter but it
would need to be hand wired to the second 5I25 I/O connector
Last edit: 9 years 3 months ago by PCW.
9 years 3 months ago #95697 by danilom
I got a board with AM26LS31 - Quadruple Differential Line Driver, datasheet says
AM26LS31 family of devices is a quadruple complementary-output line driver designed to meet the requirements of ANSI TIA/EIA-422-B
no problem with wiring it to the 5i25 second port, will I need different firmware file for it?
9 years 3 months ago #95699 by PCW
You need a differential receiver also:
FPGA TX PIN ==> DIFF DRIVER ==> TX+ and TX- ==> 7I73 RX
FPGA RX PIN <== DIFF RECEIVER <== RX+ and RX- <== 7I73 TX
If you add a 26LS32 you can make a 4 channel adapter
or if you want a single chip for RX and TX , a SP491 or equivalent
transceiver will work.
Note that you cannot use 8 pin RS-485 transceiver chips
You can use the 7I77_7I74 firmware
9 years 3 months ago #95700 by danilom
Thanks, forgot about receiver side,
I got MAX 491 , its just slower than SP491 .... 2.5Mbps max
Will try it, if nothing will order the 7i74 and put both 7i73 and 7i84 on it
9 years 3 months ago - 9 years 3 months ago #95779 by danilom
I cant seem to get it to detect the 7i73 , correct firmware is loaded in 5i25, if connected to the 7i77 rs422 port its detected right away, added sserial_port_1=00000000
MAX491 is connected like this
5i25 Port2 MAX491 7i73
pin1 --- MAX491 pin 2
pin3 --- MAX491 pin 5
MAX491 pin 12 --- RJ45 pin 6
MAX491 pin 11 --- RJ45 pin 3
MAX491 pin 10 --- RJ45 pin 1
MAX491 pin 9 --- RJ45 pin 2
5v ---- MAX491 pin 14,4 --- RJ45 pin 7,8
GND
MAX491 pin 6,7,3 --- RJ45 pin 4,5
Last edit: 9 years 3 months ago by danilom.
Time to create page: 0.056 seconds
