Chris,
Here is the entire text from the dialog.
PNCconf encountered an error. The following information may be useful in troubleshooting:
LinuxCNC Version: UNAVAILABLE
File "/usr/lib/python2.7/dist-packages/pncconf/pages.py", line 111, in on_button_fwd_clicked
self()
File "/usr/lib/python2.7/dist-packages/pncconf/pages.py", line 1393, in finished_finish
self.a.buid_config()
File "/usr/bin/pncconf", line 311, in buid_config
self.HAL.write_halfile(base)
File "/usr/lib/python2.7/dist-packages/pncconf/build_HAL.py", line 351, in write_halfile
self.connect_output(file)
File "/usr/lib/python2.7/dist-packages/pncconf/build_HAL.py", line 1721, in connect_output
write_pins(pname,p,i,t,boardnum,None,port,channel,pin)
File "/usr/lib/python2.7/dist-packages/pncconf/build_HAL.py", line 1589, in write_pins
if "parport" in pinname:
TypeError: argument of type 'NoneType' is not iterable
and here is the text from the ssh console:
**** INFO firmware 0 changed
found a sserial channel
s-stepgen-step None
s-pwm-pulse None
s-encoder-a mesa0c1pin16
/home/acondit/linuxcnc/configs/my_LinuxCNC_machine
/home/acondit/.pncconf-preferences
x False None None
tandem: False
y False None None
z False None None
x False None None
y False None None
z False None None
x False None None
y False None None
z False None None
s False None None
Is this any help?
