Gantry System reversing direction of Motor on y2
5 years 7 months ago #202229 by Creative25
I am trying to test my setup for a gantry system. So I want Stepper Motors of y and y2 to move in opposite direction. Is this done by inverting the dir pin for y2 or is there a better way of doing it?
5 years 7 months ago #202232 by PCW
I think there are at least four ways to do this, 2 in hal and 2 with wiring changes:
1. Inverting the direction pin in hal
2. Changing the sign of the step scale in hal
3. If you are using differential drive so you have
DIR+ and DIR-, swapping these will reverse the direction
4. Swapping polarity on one of the motor windings
Your choice...
5 years 7 months ago #202238 by Creative25
Thanks for the info I did not know of swapping the dir pins , do they actually swap polarity?
I will use one of the wiring methods to keep it simple.
5 years 7 months ago #202358 by andypugh
Creative25 wrote: I will use one of the wiring methods to keep it simple.
I would always do it in HAL, to keep it simple.
You will always have access to HAL, but wiring gets buried in the machine.
I generally change the sign of the step_scale.
5 years 7 months ago #202375 by Creative25
Can’t find step_scale in Hal only in the ini file.
5 years 7 months ago #202377 by andypugh
Creative25 wrote: Can’t find step_scale in Hal only in the ini file.
The HAL reads it from the INI, so change it in the INI.
The following user(s) said Thank You: Creative25
Time to create page: 0.108 seconds
