spindle config
5 years 5 months ago #208904 by bm1400
spindle config was created by bm1400
Hi all
I have a mesa 7i76e which i have managed to connect the steppers & are working,im realy strugling with the spindle connection to the vfd (minleaf AT1-2200x) the pot side is working & i can increase & decrease the speed in linuxcnc but for the life of me i cant get it to enable or reverse i have it connected:-
pin8 spindle dir +
pin7 spindle dir -
pin6 spindle ena+
pin5 spindle ena -
pin4
pin3 spindle +
pin2 spindle OUT
pin1 spindle -
if i run a wire from comon to x4 (sindle ena) it goes forward at the set speed & x5 (spindle rev) it reverses i just cant get linux th control the pins is there a way to test this please
I attatch my HAL file
Thanks in advance
File Name: lathe.hal
File Size:8.54 KB
File Name: lathe.ini
File Size:3.21 KB
5 years 5 months ago - 5 years 5 months ago #208914 by PCW
Replied by PCW on topic spindle config
You should be able to control this entirely from TB4
pin8 spindle dir+ --> X2 pin7 spindle dir- --> COM pin6 spindle ena+ --> X1 pin5 spindle ena- --> COM
The trick is figuring out the very obscure/terse manual and
setting up X1 for enable and X2 for direction
Last edit: 5 years 5 months ago by PCW.
The following user(s) said Thank You: bm1400
5 years 5 months ago #208927 by bm1400
Replied by bm1400 on topic spindle config
Thanks for the reply
i have tried as you said vfd settings
pin8 spindle dir+ --> X2 wired reverse
pin6 spindle ena+ --> X1 wired enabled
x1 & x2 are sitting at 12v & nothing changes (no voltage drop) when controlls are pressed i am at a loss as what to do next
5 years 5 months ago - 5 years 5 months ago #208929 by PCW
if LinuxCNC is running and hm2_7i76e.0.7i76.0.0.spinena is true (verify with halmeter)
and you read +12V from TB4 pins 6 to 5 (at the 7I76), the 7I76 has been damaged.
5 years 5 months ago #208936 by bm1400
If i disconect X1 & X2 Ihave zero volts on pins 5,6,7,8 using a multi meter.im not very good at linux ive only been using it for a week, if i try to use halmeter in the terminal window i get this.
(halmeter:3976): Gtk-CRITICAL **: 18:29:19.279: IA__gtk_widget_get_parent: assertion 'GTK_IS_WIDGET (widget)' failed
5 years 5 months ago #208938 by PCW
If you are using axis, try
Machine --> Show Hal Configuration --> the select hm2_7i76e.0.7i76.0.0.spinena
from pin list --> watch tab
Time to create page: 0.262 seconds
