help please ,, problems configuring PnCConf
4 years 11 months ago #228087 by Servimet
Hello everyone, let me tell you that I am a beginner in linuxcnc.
I am working on a machining center retrofiting.
  it has a whole setup of analog servodriver ..
I have two MESA 7i92m and 7i77 ..
The problem is the following, I start the configuration of pnc conf, load data and advance to table card 0.
board name ... 7i92-internal date
  firmware ... 7i77_7i76
Now I do not see options to enable the signals + -10volt in any connector.
I have no idea how to enable these signals
I really appreciate the help!!
4 years 11 months ago #228088 by tommylight
4 years 11 months ago #228108 by Servimet
hi tommylight..
pulse width modulation (pwm) does not appear that option either.
or something_ analog signal
Maybe it is something from the 7i92 / 7i77 set, they are not correct?
4 years 11 months ago #228112 by tommylight
The following user(s) said Thank You: Servimet
4 years 11 months ago #228135 by PCW
If I run pncconf and I choose 7I92 internal firmware and
7I77x2 with one 7I77 I get a "PWM" tab:
4 years 11 months ago #228155 by Servimet
Hi PCW thanks for the help..I'm from Buenos Aires, Argentina
I read your comments a lot on the forum.I attach photos.
I do not know why I do not have or the options that you have appear.pwm is not here .
.I can't solve the problem.
Time to create page: 0.127 seconds
