- Thank you received: 13
Guidance Needed! Initial LinuxCNC/PncConf setup
3 years 8 months ago - 3 years 8 months ago #264977
by Sray69
Guidance Needed! Initial LinuxCNC/PncConf setup was created by Sray69
I have finished the electrical cabinet and have connected the LCNC computer to the Mesa 7i76E and they are communicating.
My configuration:
Debian Bookworm
LCNC 2.9
Mesa 7i76e
X&Y Stepper Motors - Nema 24
Z Stepper Motor - Nema 23
Digital Stepper Driver - DM860T
Axis (3 axis) configuration - XYYZ (I only have limit switches on one of the Y axis's)
I am trying to do the initial setup in PncConf but am having trouble understanding some of the settings. When I try to Test/Tune Axis I get no movement at all. Here are my pncconf settings.
When I click Run on the X Axis Tune window I see the Hal Meter windows running but nothing at the motors.
Also when I turn the PS for the drivers/motors on the motors have resistance (holding power). If I try hard enough I can turn them but not as easy as when PS is off. I assume this means that the motors are wired correctly?
Could use some guidance.
My configuration:
Debian Bookworm
LCNC 2.9
Mesa 7i76e
Last edit: 3 years 8 months ago by Sray69.
3 years 8 months ago #264985
by 0x2102
Replied by 0x2102 on topic Guidance Needed! Initial LinuxCNC/PncConf setup
I suspect the step/dir timings are off. The Pncconf default timings are fairly high and should work.
Leave the "drive enable" pins unconnected. Drive is enabled by default
Try these settings
DIRSETUP = 15000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
Next, try some of these timings here:
www.forum.linuxcnc.org/38-general-linuxc.../36856-dm860a-driver
Try these settings
DIRSETUP = 15000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
The following user(s) said Thank You: Sray69
3 years 8 months ago #264987
by Sray69
Replied by Sray69 on topic Guidance Needed! Initial LinuxCNC/PncConf setup
Hey thanks for that. I actually saw some movement.
But it seems hit and miss. Some times when I go into the Test/Tune Axis screens I can get the axis to move using the +/- buttons on the Tune window. Other times the motor will not do anything. Even if I close the test windows and then go back in they will not work. Sometimes if I go back and to the Mesa card Configuration Page and Accept Component Changes and then go into the Test screens it may work or may not. Sometimes when I press the Run button it will cycle back and forth non-stop and other times it will just stop and I cannot get it to start again. Very inconsistent.
I have been messing with the timings but have not figured out why the inconsistencies.
Any ideas?
Any ideas?
3 years 8 months ago #264990
Replied by tommylight on topic Guidance Needed! Initial LinuxCNC/PncConf setup
Save the config, open LinuxCNC with that config, on the "machine" menu choose "calibration", tune there.
Do not forget to click "test", "OK", "save to file" before closing.
3 years 8 months ago #264993
by Sray69
I followed your instructions but I am not sure what it is supposed to do. I opened the file and it loaded. I went to machine>calibration and was able to see the settings. I was also able to save the file but I am not sure how to get it to move. Nothing seems to work.
When in the Calibration>Test environment the amber light is on on the Mesa board as it was when the motors would stop in pncconf. So nothing would move. Being new to LCNC I am kind of lost on how to manually move the axis's around.
I have also read about how in order for the two Y axis motors to work together I need to set Home. When in pncconf and testing the Y axis, only one motor turned. Any help on setting Home would be appreciated.
Thanks!
Thanks!
3 years 8 months ago #264994
Replied by andypugh on topic Guidance Needed! Initial LinuxCNC/PncConf setup
I am moving the amber light post to the driver boards section.
Time to create page: 0.217 seconds
