What PPR encoder?
7
What is the base period set at in the ini file?
setp [HMOT](CARD0).pwmgen.pwm_frequency 250
setp [HMOT](CARD0).pwmgen.pdm_frequency 6000000
setp [HMOT](CARD0).watchdog.timeout_ns 10000000
Is the encoder wired to BOB?
Yes, 5-axis Chinese BOB (ST-v2)
Are you using a VFD or a servo drive for the spindle?
Neither; using 0-10V directly to potentiometer inputs.
The signal spindle-vel-fb-rpm-abs is unconnected (so always 0)This is a pncconf bug, it should create that signal from the outputof the absolute function, something like:loadrt absaddf abs.0 servo-threadnet spindle-vel-fb-rpm abs.0.innet spindle-vel-fb-rpm-abs abs.0.out
That explains the open loop.
I'm not that great with HAL editing nor how the PID and spindle pins/parameters are supposed to be set up.
Can you explain how I should implement the above code?
Attached is the HAL provided by PNCConf and I added the lines you provided. I now get pid.s.feedback with some values.
