- Thank you received: 3
7i76e Mode 2 Selection in LinuxCNC 2.9.1 not possible anymore?!
2 years 11 months ago #284954
by N3pu
Hello World
In the past I only installed and played a bit with linuxCNC. Not I like to implement it on my new CNC mill. Because of this I installed the latest version 2.9.1 on my pc, startet pncconf and now it looks different to my old linuxcnc installation regarding the Mesa tabs.
Before I was able to get access to Mode 2 and Tab 5 / 6 etc. Now I´m not able anymore?! Or do I miss some information ?
Attached the old world (2.8.X) and the latest (2.9.1)
Thank´s
Jannik
Thank´s
Jannik
2 years 11 months ago #284984
Replied by tommylight on topic 7i76e Mode 2 Selection in LinuxCNC 2.9.1 not possible anymore?!
Edit the hal file, the line that starts with loadrt containing something like this
sserial_port_0=0020xxxx
Probably changing the first 0 after = to 2 should do the trick, no idea what channel 7i76E uses, but no harm in trying.
2 years 11 months ago #285000
Replied by cmorley on topic 7i76e Mode 2 Selection in LinuxCNC 2.9.1 not possible anymore?!
I confirm the problem and will look into it.
2 years 11 months ago #285038
by N3pu
Replied by N3pu on topic 7i76e Mode 2 Selection in LinuxCNC 2.9.1 not possible anymore?!
Thanks for answering.
I tried this is in the .hal
OLD:
#loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxxxx"
NEW:
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=20xxxxxx"
After saving I reloaded the config in pncconf but still the same. No TB5/6 options..
If there is another way around please let me know.
Or does it make sense to go with the 2.8.X version?
Finally I think I will have to some manuel adjustments to the .hal to get my setup work (withouf pncconf). Should I prefer to go on without pncconf as a newbie?
OLD:
NEW:
2 years 11 months ago #285041
That will not change anything in PncConf, it will change the Mesa card mode, so you will have access to first 4 analog inputs, 2 MPG's, and voltage reading from the power supply connector.
Use the "show hal configuration" from the "machine" menu to find the exact pin names.
2 years 11 months ago #285043
by N3pu
Okay, but that means from this point (manual change in the .hal) I have to go by hand without pncconf, right?t So I have try to write my own hal with the signals / nets. Reloading in pncconf will reset my handmade .hal modifications.
Time to create page: 0.225 seconds
