possible bug with "M66 P26 L4 Q7"? or my use of it? or with FlexGUI?
2 years 4 weeks ago - 2 years 4 weeks ago #311245 by travis036
whole config: github.com/travis-farmer/linuxcnc
my routine using it: github.com/travis-farmer/linuxcnc/blob/m...files/toolchange.ngc
(line 11)
the signal sits at LOW, but when the spindle VFD is running or braking, it goes HIGH, and falls back to LOW after the spindle stops.
what i experienced is a program hang when the routine is started with a spinning spindle, but even when the spindle completes the stop, the program then continues, but aborts for some reason, while it is probing down.
what i observed with the GUI (FlexGUI by JT) is that when M66 starts, the GUI hangs, even after the M66 passes with success. i know it hangs because i watch the hal-pin on the GUI, and it doesn't change for the signal in question (motion.digital-in-26). but as soon as it does, the tool-setter probing operation (remapped as M201) aborts.
if i change the line to "M66 P26 L2 Q7", it hangs the GUI and operations permanently, if the spindle is not turning.
what is going wrong here? is it my error? the GUI error, or a LinuxCNC error? my errors are easier to fix...
Last edit: 2 years 4 weeks ago by travis036.
2 years 4 weeks ago - 2 years 4 weeks ago #311246 by travis036
would i be better with:
M66 P26 L0     o400 if[#5399 NE 0]         M66 P26 L2 Q7         o215 if [#5399 EQ -1]             M5             (msg,Warning, spindle brake not active! PAUSED)             M0         o215 endif     o400 endif so it exits immediately if not turning, and waits for a fall event if it is turning?
Last edit: 2 years 4 weeks ago by travis036. Reason: formatting
2 years 4 weeks ago #311249 by travis036
changed to the version in my reply, now heading out to test... expecting failure... hope nothing breaks...
2 years 4 weeks ago #311251 by travis036
no joy.
even changing the polarity of the pin and using "M66 P26 L1 Q10" fails to work
2 years 4 weeks ago #311254 by travis036
i suspect if i am reading the hal pin with FlexGUI and with a M66, it may be the cause of the hang. reaching here, as i can't find any other cause...
will continue testing tomorrow...
2 years 4 weeks ago #311287 by travis036
ok, my issue was a FlexGUI bug, somewhere. i confirmed by testing again with flex to make sure no changes. then i switched GUIs to Axis and performed the same test, only in Axis everything worked as it was supposed to.
my tool changer routine contains a M66 line. with the digital pin in the M66 cleared (spindle not running), the routine works fine. i issue a "T1 M6", and it changes tools and probes the tool and returns to resting position.
with the digital pin not cleared (spindle running), i issue a "T1 M6", and it stops the spindle, waits for it to stop (GUI Hangs), then changes and starts probing but aborts when the GUI stops hanging.
again, under Axis, this is not an issue, as to say it all works as it is supposed to.
i used Hal Show to view the pin status while in FlexGUI, and the pin changes when it is supposed to, without hang. it is the GUI hanging during a M66 wait.
Time to create page: 0.450 seconds
