Laser power scaling based on speed and direction
2 years 3 weeks ago #311680 by iforce2d
Recently I have been playing around with a cheap laser module, and found myself wanting to scale the power based on speed and direction. The reason for scaling with speed should be obvious. The reason for scaling with direction is that the laser beam is kinda rectangular and therefore cuts more effectively along one axis than the other - seems to be common with these cheap diode lasers.
I know there is already a component to handle some of these requirements, but I wanted to try making my own. Here is what I came up with:
component laserreg ""; pin in   float inpower    "Desired laser power at constant speed"; pin in   float reqspd    "Requested speed, connect to motion.requested-vel"; pin in   float curspd    "Current speed, connect to motion.current-vel"; pin in   float velx    "Current speed x component, connect to joint.0.vel-cmd"; pin in   float vely    "Current speed y component, connect to joint.1.vel-cmd"; pin in   float share    "Fraction of power given to pure Y movement, eg. 0.6"; pin out  float outpower "Scaled output laser power"; function _ fp "Update the laser power"; license "GPL"; ;; #include <math.h> FUNCTION(_) {     outpower = inpower * (curspd / reqspd);          float angle = atan2(fabs(velx), fabs(vely));  // angle away from y in radians     float horz = angle / (0.5*M_PI);          // 1 when moving perfectly along x axis     outpower *= share + (1-share) * horz;     if ( outpower > inpower )         outpower = inpower;             if ( outpower > 100 )         outpower = 100;             if ( outpower < 0 )         outpower = 0; }
One nice side effect is that I can now pause the job at any point and the laser will turn off, and resuming from the middle of a cut works nicely too. Previously I had to be careful to only pause between cuts, otherwise the laser would stay on!
Here is an example .hal file to use the component. This assumes that laser power is controlled by setting spindle speed, and is expressed in gcode as a value between 0 and 100 (eg. M3 S95). For my machine the desired final output is a value between 0 and 65535 so I'm using a lincurve to map to that range, you can remove or change that as appropriate for your case. This example also assumes that joint0 and joint1 have a trivkins type relation to movement in the X and Y axes respectively.
The current speed in each axis is obtained from joint.N.vel-cmd which might not be the actual speed, but it doesn't matter because all we need is the ratio between x/y to know the direction. My laser cuts more effectively in Y than X, so this configuration will scale the power down for Y movements. Swap the X and Y vel-cmd if your laser is the other way around. The value of 0.75 for 'share' comes from some experimentation to see how much a cut with pure Y movement needed to be scaled down to give the same cut effectiveness as a pure X movement. A value of 1 will result in no scaling.
loadrt lincurve personality=2 loadrt laserreg addf lincurve.0 servo-thread addf laserreg.0    servo-thread # Laser power mapping (0-100 -> 0-65535) setp lincurve.0.x-val-00 0 setp lincurve.0.y-val-00 0 setp lincurve.0.x-val-01 100 setp lincurve.0.y-val-01 65535 net laser-requested-speed    motion.requested-vel    => laserreg.0.reqspd net laser-current-speed        motion.current-vel    => laserreg.0.curspd net laser-velx            joint.0.vel-cmd        => laserreg.0.velx net laser-vely            joint.1.vel-cmd        => laserreg.0.vely setp                laserreg.0.share    0.75 net laser-percent        spindle.0.speed-out    => laserreg.0.inpower net laser-regulated-percent    laserreg.0.outpower    => lincurve.0.in net laser-65535                lincurve.0.out          => weeny.spindle.set-speed
Some examples of the outcome. First, the result without using any power compensation:
With speed compensation only:
With speed and direction compensation (could still use a little less power in Y moves):
2 years 3 weeks ago #311681 by iforce2d
btw here is the program I used to cut those test squares with various speeds and laser powers. Change the first four lines as required. Note that the comparisons in the loop are 'less than' and 'greater than', not 'greater than or equal', the power loop increments and the speed loop decrements, so the result of the settings as shown will be powers from 10 - 90, and speeds from 800 - 400. The line immediately before each 'endwhile' can be changed to increment by different amounts. 'Size' and 'margin' can be changed to alter the size of the cut squares.
#<minpwr>=10 #<maxpwr>=91 #<maxspd>=800 #<minspd>=399 #<size>=6 #<margin>=2 #<stride>=[#<size>+#<margin>] g21 #<x>=0 #<y>=0 #<pwr>=#<minpwr> #<spd>=#<maxspd> o101 while [#<pwr> LT #<maxpwr>]   #<y> = 0   #<spd>=#<maxspd>   o110 while [#<spd> GT #<minspd>]     g0 x#<x> y#<y>     m3 s[#<pwr>]                 g1 y[#<y> + #<size>] f#<spd>     g1 x[#<x> +#<size>]     g1 y#<y>     g1 x#<x>     m5     #<y> = [#<y> + #<stride>]     #<spd> = [#<spd> - 100]   o110 endwhile   #<x> = [#<x> + #<stride>]   #<pwr> = [#<pwr> + 10] o101 endwhile m2
The following user(s) said Thank You: tommylight, poesel
7 months 3 weeks ago #344086 by kb0thn
Much thanks to iforce2d for this implementation and write-up. I just deployed a slightly tweaked version of it to my 4x10' router that has a 40 watt laser as second spindle.
I had to modify the component to force zero power output when there was no motion. It looks like the original first line of code can result in a NaN and then my machine was ending up with a 50% PWM output in that state. So I force NaN to zero. That worked okay in my testing at a fixed z height. But when running an actual program I retract Z between parts and I was finding that Z only motion was leaving the laser stuck on. So now I also force zero power output when X and Y motion are essentially zero.
component aprs_laserreg ""; pin in float inpower "Desired laser power at constant speed"; pin in float reqspd "Requested speed, connect to motion.requested-vel"; pin in float curspd "Current speed, connect to motion.current-vel"; pin in float velx "Current speed x component, connect to joint.0.vel-cmd"; pin in float vely "Current speed y component, connect to joint.1.vel-cmd"; pin in float velz "Current speed y component, connect to joint.1.vel-cmd"; pin in float share "Fraction of power given to pure Y movement, eg. 0.6"; pin out float outpower "Scaled output laser power"; function _ fp "Update the laser power"; license "GPL"; ;; #include <math.h> FUNCTION(_) { outpower = inpower * (curspd / reqspd); float angle = atan2(fabs(velx), fabs(vely)); // angle away from y in radians float horz = angle / (0.5*M_PI); // 1 when moving perfectly along x axis outpower *= share + (1-share) * horz; if ( outpower > inpower ) outpower = inpower; if ( outpower > 100 ) outpower = 100; if ( ( fabs(velx)<1e-6 && fabs(vely)<1e-6 ) || isnan(outpower) || outpower < 0 ) outpower = 0; }
I use a bunch of MESA cards including a 7I77 and a 7I76. And then some additional IO boards linked via serial. I never figured out how to get a hardware PWM output. So I am using software PWM for driving the laser. Here are the relevant sections of my custom.hal file showing how it all goes together:
# laser engraver # software PWM loadrt pwmgen output_type=0 addf pwmgen.update      servo-thread addf pwmgen.make-pulses servo-thread # should be base-thread setp pwmgen.0.enable TRUE setp pwmgen.0.scale 65535 # based on https://forum.linuxcnc.org/47-hal-examples/54073-laser-power-scaling-based-on-speed-and-direction loadrt lincurve personality=2 loadrt aprs_laserreg # for some reason the component gets renamed to aprs-laserreg (ie changes _ to -) addf lincurve.0         servo-thread addf aprs-laserreg.0    servo-thread # I don't seem to have a base-thread. I think because it is MESA # Laser power mapping (0-100 -> 0-65535) setp lincurve.0.x-val-00 0 setp lincurve.0.y-val-00 0 setp lincurve.0.x-val-01 100  setp lincurve.0.y-val-01 65535  net laser-requested-speed      motion.requested-vel    => aprs-laserreg.0.reqspd net laser-current-speed        motion.current-vel      => aprs-laserreg.0.curspd net laser-velx                 joint.0.vel-cmd         => aprs-laserreg.0.velx net laser-vely                 joint.1.vel-cmd         => aprs-laserreg.0.vely net laser-velz                 joint.2.vel-cmd         => aprs-laserreg.0.velz setp aprs-laserreg.0.share     1.0  net laser-percent              spindle.1.speed-out      => aprs-laserreg.0.inpower net laser-regulated-percent    aprs-laserreg.0.outpower => lincurve.0.in net laser-65535                lincurve.0.out           => pwmgen.0.value net laser-pwm                  pwmgen.0.pwm             => optimat_o_laser_engraver_pwm # second spindle we will always consider to be at speed net laser-at-speed => spindle.1.at-speed sets laser-at-speed true
7 months 3 weeks ago #344111 by PCW
To get hardware PWM you need to have firmware on the FPGA that supports PWM.
For example if using a 7I76, there is FPGA firmware that replaces 1 Step/Dir output
with hardware PWM/Dir
7 months 3 weeks ago #344112 by kb0thn
I have a 7I77 and a 7I76 hooked to a 5i25. And then there is a 7I66-8 and a 7I66-24 connected via serial (but I don't think those matter).
I looked for a while and didn't find / couldn't figure out with firmware I would need. Can you recommend an exact firmware?
Thanks!
Time to create page: 0.058 seconds
