LinuxMint stopped working now I got problems reinstalling it.
8 years 6 months ago #109582 by kor
For some unknown reason my linuxmint preempt rt stopped working after and update. Right after each bootup I got an error that login was shorter than 10 seconds and I wasn't able to login.
So I used some old live got my configs. and reinstalled linuxmint 18.1 with the guide from the forum, which I used before without any issue. I was not able to use the newer kernel 4.9.4-RT2, like last time but the 4.8.11 rt7 worked.
I can not explain why it worked before and now it doesn't.
and now when I want to install linuxcnc going to linuxcnc-dev/debian/
and doing the ./configure uspace
I get the following error:
libxenomai-dev exists, but information about its source package is not available. This most likely means you do not have the right deb-src lines in etc/apt/ or that you need to apt-get update.
I have done the sudo apt-get update but that didn't help.
I get kind of frustrated that I am fixing problems on the OS/linuxcnc and not on my lathe/controller, for 3 days in a row.
  • ozzyrob
  • New Member
  • New Member
8 years 6 months ago #109615 by ozzyrob
What is the output of uname -a
The libxenomai reference is odd,
Did you compile your own kerenel ? Or install one via a deb ?
8 years 6 months ago #109619 by tommylight
Most probably you have "important security updates" and "recomended updates" disabled, or "partners" not enabled. From synaptics package manager >settings>software sources> and check that there.
  • ozzyrob
  • New Member
  • New Member
8 years 6 months ago #109621 by ozzyrob
Apparently
./configure uspace noauto
is the go
Are you having issues with the official linuxcnc distro (as that is the easiest option) or are there other reasons ?
8 years 6 months ago - 8 years 6 months ago #109751 by kor
output of uname -a:
Linux kor-lathe 4.8.11-rt7 #1 SMP Sat Apr 21 16:05:54 CEST 2018 x86_64 x86_64 x86_64 GNU/Linux
and this is the entire output of the configure uspace noauto:
~/linuxcnc-dev/debian $ ./configure uspace noauto W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (main/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (universe/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (universe/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (universe/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (universe/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (main/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (universe/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (universe/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (universe/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (universe/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (main/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (universe/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (universe/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (universe/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (universe/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2 W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (main/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (universe/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (universe/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (universe/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (universe/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:3 Package libxenomai-dev exists, but information about its source package is not available. This most likely means that you do not have the right deb-src lines in /etc/apt, or that you need to "apt-get update".
I couldn't find the mentioned options "important security updates" and "recomended updates" disabled, or "partners" under synaptec > settings> paket sources
did you compile your own kerenel ? Or install one via a deb ?
i used the tutorial linuxcnc 18.1 mint preempt rt
Last edit: 8 years 6 months ago by kor.
  • ozzyrob
  • New Member
  • New Member
8 years 6 months ago #109752 by ozzyrob
Your problem seems to stem from (multi configurations in your apt sources, as best as I can tell not being a debian/ubuntu/mint expert, Slackware is more my thing.
"W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/additional-repositories.list:1 and /etc/apt/sources.list.d/additional-repositories.list:2"
And others similar
I think this may fix your apt-sources.lst or at least give you some direction in fixing the issue, this would appear to be more of a debian/ubuntu/mint issue rather than an actual linuxcnc issue.
askubuntu.com/questions/760896/how-can-i...gured-multiple-times
Time to create page: 0.096 seconds
