No suitable memory target error following gnipsel.com Mint Preempt Kernel Patch
7 years 4 weeks ago #147119 by pmconsulting
I have a 64 Gb SSD drive & successfully installed Mint 19.1. I followed the instructions here: gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html
After installing the Grub Customizer & rebooting I am unable to start the system. I'm getting an error "no suitable memory target found".
During the install, I allowed the Mint installer to create default partitions on the drive. Do I need to manually create root, home & swap partitions to get rid of this error? Is there something I can during the xconfiguration step to reduce the size - perhaps strip developer modules?
7 years 4 weeks ago #147122 by bevins
pmconsulting wrote: I have a 64 Gb SSD drive & successfully installed Mint 19.1. I followed the instructions here: gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html
The kernel modules were built with all symbols. So your initrd is probably way bigger than it is suppose to be.
I had the same problem.
7 years 3 weeks ago #147157 by andypugh
bevins wrote: I had the same problem.
And what was your solution? :-)
7 years 3 weeks ago - 7 years 3 weeks ago #147208 by pmconsulting
That's where unix starts to turn Greek to me. Kernel modules, symbols & initrd are all just strange words. I have a hunch that kernel modules are similar to apache modules, but I have no idea what symbols are or what an initrd is let alone what I'm supposed to to to them or how I'm supposed to do it.
Last edit: 7 years 3 weeks ago by pmconsulting.
7 years 3 weeks ago - 7 years 3 weeks ago #147228 by bevins
Install Debian 9.
I tried stripping symbols and spent about hours on it. I needed to get up and running so I installed Debian 9.
I will revisit soon though as I want mint
Last edit: 7 years 3 weeks ago by bevins.
7 years 3 weeks ago #147245 by bevins
The kernel makefile should strip debug symbols with.... make INSTALL_MOD_STRIP=1 modules_install or
Make sure CONFIG_DEBUG_INFO is not defined.
This should work. I haven't tried it but will as soon as I get a chance.
Time to create page: 0.131 seconds
