Hi Everyone,
My apologies for the long description, but it seems like something in the steps I have been taking must be the root cause. After successfully using 2.7 for quite a while, I decided to upgrade to 2.8 using the ISO. Initial issues with the USB were solved by using a CDROM instead of a USB stick and the installation was successful and I was able to use my CNC again after some minor edits to the HAL.
The other day while doing some other odds and ends, I installed Chrome and VisualCode on the system, but then didn't check anything further.
Today, I wanted to start getting git installed and merge my edits to git when I noticed that the system was not recognizing the USB. I tried rebooting, but found that the logout screen was abnormal (no hibernate and restart and shutdown both greyed out). I could only logout, nothing more and this resulted in a blinking cursor and nothing else on the screen. CTRL-ALT-DEL forced it to do a proper shutdown and restart, but now it would only log in to the console, no XFCE anymore. sudo startxfce4 would still start the GUI, but as root.
Since I didn't have a lot invested at this point, I decided I had done something very bad and the best thing to would be to simply re-install from the ISO. That was quickly done. I killed wicd and replaced it with network-manager and set up the connection to my 7i76e. And then I installed git using sudo apt-install git-all. This installed quite a lot, I don't have a log of everything, but I assume it was all normal.
At the end of all that, I went to ping my mesa card and received no response. And then realized that network-manager was not running either. And the logout screen would again only allow a logout and not a restart. And now it is booting back to the console again.
Has anyone seen this behaviour? Any idea what it is that I might be doing wrong?
Motherboard is a J3455B-ITX with a 500GB samsung SSD that ran very solid under 2.7.
Kind regards,
Sam
