when an inch isn't
2 years 4 months ago #303841 by Irritant
when an inch isn't was created by Irritant
Hi,  trying to get the travel to actually measure correctly.
I have entered:
200 motor steps
1.9 microstep
pulley 1:1
max velocity
max accel 30
Right now an inch measures 1.016"
What is my next step?
Cheers!
2 years 4 months ago #303843 by Aciera
Replied by Aciera on topic when an inch isn't
1.9 microstep
Microstepping is usually a number that is a power of two (ie 2,4,8,16).
Your .ini file would help.
2 years 4 months ago #303871 by Cant do this anymore bye all
Technically an inch is actually defined as 25.4mm, this came about in the 1930 or so as different regions had different definitions. The development of slip gauges or "Joe Blocks" had a bit to do with this.
I still can't understand why some regions of the world will attempt to use anything to avoid using the metric system......Yes it's as big as 3 football fields and as deep as 4 school buses.
en.wikipedia.org/wiki/Inch
Tho it makes no reference to slip gauges.
The following user(s) said Thank You: Irritant
2 years 4 months ago #303872 by Cant do this anymore bye all
Leadscrew ptich is required or the numbers mean nothing (or if belt drive belt pitch)
2 years 4 months ago #303904 by scotth
Replied by scotth on topic when an inch isn't
Look at geometry and lost motion.
2 years 4 months ago #303906 by scotth
Remember that the distance between London and Paris is the same whether you represent it in kilometers or miles. The only difference is the way you slice it.
Time to create page: 0.061 seconds
