Help with Mesa 7I97T card Servo wiring
2 years 1 month ago #310630 by akim14
I need help assigning the right wires  between the Mesa 7i97t  and SG-AS50 servo drive, I read the Mesa manual for the 7I97T and have seen  a  lot examples that deals with steppers. but cant seem to find information using similar servo drives that I have
2 years 1 month ago #310656 by PCW
As an example of the basic connections for  channel 0:
7I97T                    Drive
AOUT0 TB3.4        V-REF CN3.1
GND     TB3.3       GND    CN3.16
ENA0+ TB3.2       S-ON   CN3.7
ENA0-   TB3.1       24V    GND
QA0      TB1.1       PA0   CN3.10
/QA0     TB1.2       /PA0   CN3.11
QB0      TB1.4       PB0    CN3.12
/QB0     TB1.5       /PB0   CN3.13
IDX0     TB1.7       PC0    CN3.14
/IDX0    TB1.8       /PC0   CN3.15
The following user(s) said Thank You: Hartwig
2 years 1 month ago #310668 by akim14
It makes a lot more sense, now it uses the encoder values from the drive, your the greatest , thank you so much. I was looking for the pulse of reference and the sign of reference all this while
2 years 1 month ago #310803 by akim14
I have another challenge to  overcome I cant seem to get the 7I79 board to work it shows that its unsupported,
2 years 1 month ago #310807 by akim14
it was a typo I had to used 7I79T I should just use 7I79, the connection  did not work , for some reason the network is interminting
2 years 1 month ago #310856 by PCW
If you have a 7I97T you need to have the latest mesaflash
The LinuxCNC ISO includes  version is 3.4.9 which does
not support the 7I97T
github.com/LinuxCNC/mesaflash
 (build instructions on bottom of page)
Time to create page: 0.392 seconds
