Installation Error
2 years 1 week ago #312784 by HogWild
Installation Error was created by HogWild
I downloaded the “LinuxCNC 2.9.3  Debian 12 Bookworm PREEMPT-RT ISO ” from the downloads page on this site on a Windows laptop and used Rufus to create a bootable USB flash drive (using a new USB drive).
I put this USB in my industrial PC (IPC) and booted.  Chose the option to boot from the USB iso image and Debian loaded and I was able to run the Linux CNC software.
I then powered off the IPC and rebooted.  This time I chose the “Install” option to install Dorian and LinuxCNC on my SSD.  In this step: “Detect & Mount Installation Media”, I get this error (no matter how many times I retry):
”Your installation media couldn’t be mounted.” (see attached screenshot)
A question about this error:
- is this saying it can’t mount my USB drive? … or can’t mount my SSD?
And a couple of general install questions from a Linux newbie:
- how much space is needed on my SSD for installation of Dorian and LinuxCNC combined?  Note what I’m trying to install listed in previous paragraph).
- any recommendations on how my SSD should be partitioned for best performance?
Thanks for your help.
2 years 1 week ago #312790 by tommylight
Replied by tommylight on topic Installation Error
When it gets to that error:
-remove the USB
-wait 15 seconds
-plug in the USB
-wait 15 seconds
-press or click retry
2 years 1 week ago #312952 by HogWild
Replied by HogWild on topic Installation Error
It sounds like this message is indeed referring to the USB flash drive, thank you.
I have a new SSD ordered that should arrive tomorrow. After I get it installed, I’ll attempt the install again.
Any feedback on how this new SSD should be partitioned for best performance? Or will the install partition it appropriately?
2 years 1 week ago #312954 by tommylight
2 years 1 week ago - 2 years 1 week ago #313168 by HogWild
An update:
Ordered and installed a 500Gb SSD to replace the128GB SSD in my industrial PC (IPC).
I then retried the install from my bootable flash drive with the Debian/LinuxCNC install iso.
It again had the error trying to mount the iso on the USB drive so I did as described above…removed the USB drive, waited 15 seconds, re-inserted the USB drive, waited another 15 seconds, and selected the “Try again” option.
This time it mounted the iso on the USB drive successfully and continued with the install.
I went with the suggested partitions and sizes. However, it created a 1Gb swap partition and I had planned to make this at least 4Gb (since the IPC has 4Gb of memory). Oh well, hopefully 1Gb is plenty.
Remainder of install went off without a hitch. Rebooted from the fresh install on the new SSD and Dorian is up & running. Added a USB WiFi stick and loaded the drivers for it and now WiFi is working.
Powered off and moved the IPC upstairs where I only have a WiFi internet access. WiFi connected fine, but date shifted back to a day in June 2024…so I couldn’t get a secure (https) connection to any online web page.
So I googled configuring NTP for a WiFi connection, issued the NTP install command, and after installing I looked up and date/time were set correctly…and now https works fine for connecting to online web pages.
I’m a Linux newbie so happy to get this install working. Hopefully there is no conflict between NTP & LinuxCNC, anyone know?
I started LinuxCNC to take a look around. It immediately asked me to load a machine configuration so I just closed it as I have no idea which one to select.
Now it’s time to read LinuxCNC documentation…
Last edit: 2 years 1 week ago by HogWild. Reason: Spelling error
2 years 1 week ago #313169 by tommylight
NTP is ok, but might cause occasional latency warnings.
Start LinuxCNC and choose ant of the SIM configs, then close, then open again and choose a different one, play around and test as much as you like.
It does everything in sim as if it is a real machine, so very good for learning.
The following user(s) said Thank You: HogWild
Time to create page: 0.076 seconds
