Fresh install Error at start
6 years 8 months ago #158103 by alkabal
Hi
I have try many things for start SIM Gmoccapy and does not found a solution for the error. (Run in place Instal compiled from master branch)
The error is the same as this one forum.linuxcnc.org/9-installing-linuxcnc...rial?start=10#143753
Traceback (most recent call last): file "/usr/lib/python2.7/dist-packages/gladevcp/iconview.py".line 179, in __init__ self.dirIcon = self._get_icon("folder") file "/usr/lib/python2.7/dist-packages/gladevcp/iconview.py". line 265, in _get_icon return them.load_icon(name, self.icon_size, 0) GError: Icon 'gtk-directory' not present in theme (on a dialog box with an ok button) after clearing that error, the traditional linuxcnc screen comes up and almost immediatly the second error dialog box comes up as follows: Found an error! The following information may be useful in troubleshooting: Traceback (most recent call last): File "/usr/bin/gmoccapy, line 5158, in <module> app = gmoccapy(sys.argv) File "/usr/bin/gmoccapy", line 336, in __init__ self._init_iconFileSelection() File "/usr/bin/gmoccapy", line 2061, in _init_IconFileSelection self.widgets.IconFileSelection1.show_filelabel(False) File "/usr/lib/python2.7/dist-packages/gladevcp/ iconview.py", line 386, in show_fileLabel self.file_label.hide() AttributeError: 'IconFileSelection' object has no attribute 'file_label'
Br
6 years 8 months ago #158134 by bbsr_5a
Hi
what system are you on Mint Debian Ubuntu
Version of the kernel you use uname -a
does axis sim startup
6 years 8 months ago #158169 by alkabal
Hi
I have follow this gnipsel.com/linuxcnc/uspace/rpi4-emc.html
so this is debian 10
Linux raspberrypi 4.19.71-rt24-v7l+ #2 SMP PREEMPT RT Thu Feb 20 23:56:57 GMT 2020 armv7l GNU/Linux
I have installed many things like gnome-icon-theme libgtk-3-dev and other.
Openbox as GUI.
Yes Axis work fine in sim.
Many thanks for reply
6 years 8 months ago #158183 by bbsr_5a
so my guess is that the raspberry dies not have the actuly GTK and Qtvcp version to get gmoccapy to view if axis is up SIm running
not many using a Graphic high end on a low processor
6 years 8 months ago - 6 years 8 months ago #158198 by ikkuh
Replied by ikkuh on topic Fresh install Error at start
alkabal wrote: Hi
I had terrible problems getting LinuxCNC and add-ons to work on Debian 10. I switched to Debian 9 and everything started to work (and still works)
Last edit: 6 years 8 months ago by ikkuh.
6 years 8 months ago #158343 by alkabal
Hi
Thanks all for suggestion, i plan to try later with debian strech if availble for rpi4.
Br
Moderators: newbynobi, HansU
Time to create page: 0.342 seconds
